Hi
My new computer has no fire wire connection. I bought new USB HD camcorder, but I'd like to use my old SD as well. My old Sony cam has only fire wire connection. I bought fire wire to usb cabel, but looks like my computer doesn't detect my old cam.
How to make it work?
thanks
J
as you found out the hard way, they don't work. hech has the right idea.I bought fire wire to usb cabel--
This is an example of a desktop firewire add-on card for a vacant PCI slot:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16815265002
This is an example a desktop firewire add-on card for a vacant PCI-e slot:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16815166018
Adding an expresscard port to a laptop is impossible unless it has an ExpressCard slot. This is an example of a ExpressCard add-on firewire card:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16839328006
Sony Vegas and my new camcorder. Pls advice
By jazu in forum EditingReplies: 6Last Post: 27th Feb 2012, 10:23 -
Hi8 player to DVD recorder - S Video cable, RCA or Fire Wire?
By Dixie Paul in forum Newbie / General discussionsReplies: 10Last Post: 5th Jan 2010, 09:56 -
By Dixie Paul in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Jan 2010, 12:33 -
Need Advice Partitioning New Comp
By videocheez in forum ComputerReplies: 5Last Post: 27th Jun 2008, 04:37 -
can usb replace fire wire cable??
By Berghof in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2007, 23:48
