As titled, please help to convert the following preset to FFmpeg command line so that I can run it on Windows command prompt.
Thanks!!
My FFmpeg version:
FFmpeg version SVN-r26400, Copyright (c) 2000-2011 the FFmpeg developers
built on Jan 18 2011 04:07:05 with gcc 4.4.2
configuration: --enable-gpl --enable-version3 --enable-libgsm --enable-libvorb
is --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg
--enable-libschroedinger --enable-libopencore_amrwb --enable-libopencore_amrnb
--enable-libvpx --disable-decoder=libvpx --arch=x86 --enable-runtime-cpudetect -
-enable-libxvid --enable-libx264 --enable-librtmp --extra-libs='-lrtmp -lpolarss
l -lws2_32 -lwinmm' --target-os=mingw32 --enable-avisynth --enable-w32threads --
cross-prefix=i686-mingw32- --cc='ccache i686-mingw32-gcc' --enable-memalign-hack
FFmpeg SVN-r26400
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavcodec 52.108. 0 / 52.108. 0
libavformat 52.93. 0 / 52.93. 0
libavdevice 52. 2. 3 / 52. 2. 3
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
[Main]
Name=WD TV Live (mkv)
Manufacturer=Western Digital
Format=matroska
ExtName=mkv
V1Codec=libx264
V1GOPSize=0
V1MinGOPSize=0
V1FrameRateDefault=25
V1Bitrate=1500
V1Profile=1
V1Level=41
V1NbBFrames=3
V1BframeMode=3
V1AdaptiveBFrames=1
V1BRDO=1
V1WeightedBPrediction=1
V1BiDirectionalME=1
V1BFramePyramid=0
V1BframeBias=0
V1AdaptiveDCT=0
V1I8x8=1
V1I4x4=1
V1P8x8=1
V1P4x4=1
V1B8x8=1
V1MaxBitrate=24000
V1VBVBuffer=24000
V1VBVInitialBuffer=0.9
V1BitrateVariance=1.0
V1QuantCompression=0.6
V1MERange=16
V1SCDSensitivity=40
V1MEAlgorithm=1
V1SubPelRefinement=5
V1ChromaME=1
V1MaxQuant=69
V1MinQuant=10
V1MaxQuantDelta=4
V1IPFactor=1.4
V1PBFactor=1.3
V1DeadZoneInter=21
V1DeadZoneIntra=11
V1AQmode=1
V1AQstrength=1.0
V1Trellis=0
V1NbRefFrames=2
V1MixedRefs=0
V1Cabac=1
V1NoDCTDecimate=0
V1NoFastPSkip=0
V1TrellisStrenght=0.0
V1RDStrenght=1.0
V1Deblock=1
V1AlphaDeblock=0
V1BetaDeblock=0
V1Lookahead=40
V1MBTree=1
V1NoPsy=0
V1SlicesNb=0
V1MaxSliceSizeBytes=0
V1MaxSliceSizeMBs=0
V1Preset=4
V1Tuning=0
A1Codec=libfaac
A1ObjectType=lc
A1MpegVersion=mpeg-4
A1SampleRateDefault=48000
A1BitrateDefault=128000
AChannelDefault=stereo
ResDefault=720x576
Aspect1=16:9
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Closed Thread
Hi
Your FFmpeg was built on Jan 18 2011.
Preset options may have changed since then.
Think about using a new Windows build from zeranoe.com
Can you please stop create new similar threads? Just use https://forum.videohelp.com/threads/343356-FFmpeg-Command-Lines-for-Converting-Video-to...49#post2139549
Reply to it post new info.
Paid Job - Convert Preset Files to FFmpeg Command Lines
By raymng in forum ProgrammingReplies: 0Last Post: 19th Feb 2012, 03:01 -
ffmpeg / H264 (need help to build an optimized command line)
By iwiiiiiiiiii in forum Video ConversionReplies: 13Last Post: 22nd Oct 2011, 10:41 -
ffmpeg tga to x264 command line ?
By krohm in forum Video ConversionReplies: 71Last Post: 6th Jul 2010, 02:01 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 03:14 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29
