Results 1 to 15 of 15
  1. Hi, folks.
    Now, the problem is how to cut properly a mpeg2 stream. I have this video:
    http://www.4shared.com/video/SDe-1lgS/Keyframe.html
    from a TV capture. Sorry for the bad quality.
    I use to cut it with Womble Mpeg Video Wizard. The most of videos, I can convert to RMVB using EasyRealMediaProducer (ERMP). But few of them refuses to play after conversion. Like this one:
    http://www.4shared.com/file/c7JINtVO/Keyframe.html
    from the previous source above.
    I tried navigate on keyframes (I-frames) with Womble, but I didn't find how to. I suspect that the problem with few videos refusing to play is because of lack of care with I-frames. I don't understand why the first frame of a video is not a keyframe. I think it is, but what's the problem, then? Or, why the resulting video doesn't play.
    If I use Avidemux to create an AVI video with the same source, the resulting video plays fine.
    Some questions:
    1 - Why ERMP creates a file that won't play?
    2 - Why ERMP creates some files that play fine? (with the exactly same parameters - default)
    3 - Is the problem with keyframes? Or with ERMP?
    4 - How to navigate by keyframes using Womble?
    5 - How to navigate by keyframes using Mpeg StreamClip? (CTRL-K) goes to it, but stops on it, and << >> buttons forwards 10 secs, not keyframes.
    Thank you.
    Oct 2005
    666th portal
    why do you convert to rmvb? it's about the worst format ever invented.
  3. Originally Posted by aedipuss View Post
    Because I don't care with quality for some videos and it can reduce the file size to half or more. But other stuffs I use x264 and quantization matrix.
    BTW, do you have some answers for the questions?
    Thank you.
  4. It plays fine here in every player
    Probably something wrong with your playback setup
    You will get better quality and smaller filesize with the optimal x264 settings and if you prefilter
  5. Originally Posted by poisondeathray View Post
    Or it'll be driving me to another codec nightmare...
    Thank you.
  6. Thank you, poisondeathray, for your kind and prompt response. May you explain questions 4 and 5?
    Thank you.
  7. mpc, mpchc, vlc , kmplayer, smplayer all play it fine
    vlc and smplayer do not rely on system installed codecs, test with those
    Womble smart renders, so it doesn't matter where you cut
    Not sure about mpegstreamclip
  8. Originally Posted by poisondeathray View Post
    Yes, you're right! VLC plays fine. I was trying with GomPlayer, codec based.
    Womble smart renders, so it doesn't matter where you cut.
    Good to know. But sometimes I try to open a file with Avidemux (not from Womble source) and it says it needs to rebuild index. After that, the first frame is not I-frame, but P-frame. How is it possible to have a video file which first frame is not a keyframe? And how to deal with that? Cutting more?
    ERMP has an editing tool and the solution I found is to cut some ms ahead and try again, until it plays fine. Because of that, I was guessing that the problem was related with keyframes.
    Never mind.
    Thank you.
  9. Originally Posted by jairovital View Post
    Display order is not always the same as encoding order (frames can be stored in different order than which they are displayed) . It shouldn't matter with most software. If you need an I-frame (display or encoded order), then cut on I-frames on the original source (e.g use mpg2cut2 or avidemux to cut)
    For the directshow playback issue , you can try enabling rmvb in ffdshow, or maybe install real alternative
  10. Originally Posted by poisondeathray View Post
    Sometime with videos from vimeo I get those "rebuild index needed" warning when openning with avidemix. If I try to cut in the next I-frame I would lost too many frames before. Nothing to do with this? Is not possible to force avidemux to process (creates) a video before that next I-frame?
    avidemux says "first frame must to be an I-frame".
    Thank you.
  11. Sometime with videos from vimeo I get those "rebuild index needed" warning when openning with avidemix. If I try to cut in the next I-frame I would lost too many frames before. Nothing to do with this? Is not possible to force avidemux to process (creates) a video before that next I-frame?
    1) Vimeo doesn't use mpeg2, it uses h.264
    2) avidemux cannot smart render h.264 (cannot make frame accurate cuts) , use something else like videoredo beta , or solveigmm (these 2 are not free)
    or , if you are re-encoding anyway, then specify your cuts in something like avisynth
    In general, if you use closed GOP's , then every frame within that GOP will only be referenced within that GOP (i.e. there will be no references to frames outside of that GOP) - so if you "cut on keyframes" (technically it's right before the keyframe), every cutsite will begin with an I-frame
  12. Great! Answered all my doubts!
    Thank you.
  13. Originally Posted by poisondeathray View Post
    I thought the thread was closed, but following your advice, I got videoredo 3 beta (trial) and it says:
    "H.263/AVC video streams are not supported in this version"
    Going to test solveigmm...
    Thank you.
  14. Originally Posted by jairovital View Post
    for videoredo you need version 4.x, not 3
    videoredo tv suite h.264 4.x
    http://www.videoredo.com/en/index.htm
  15. Originally Posted by poisondeathray View Post
    Videoredo 4 beta says:
    "MPEG audio Layer 1 is not supported"
    Also: it crashes when I try to close application.
    SolveigMM is OK. Opened it without question. Thinking to buy it. But if Avidemux plans to make frame accurate cuts in a close future...
    Thank you.
