i want add audio to file ssif
pls help me?
tsmuxer not support
Results 1 to 9 of 9
No. Please wait some weeks before you bump/reply your thread.
A SSIF file is <PART> of a complete authored & compiled BD3D disc. It is NOT supposed to be used in standalone mode without having ripped & demultiplexed (demux) it to it's standard TS container (or even to its elementary streams).
If you go to the trouble of ripping & demuxing, you'll be able to use the TS or elementary streams as input to a NEW BD3D authored composition (using BD3D authoring app, such as comes with Vegas Pro 11). THAT is where you would be able to add a separate (or additional) audio.
I'm guessing that you don't intend to go to all that trouble. If that is the case, you're SOL. I know of no apps that "add" audio to either 2D or 3D authored BD discs.
What might get you by: Playing the decrypted SSIFs with Stereoscopic player, but telling the player to play the audio from a separate source. Might work, might not...
Scott -
The Popcorn Hour A-400 can play SSIF files in 3D, and it's a perfectly valid format to be used stand-alone.
SSIF (stereoscopic interleaved file) is in fact an m2ts file with sequence of packets from of the base view m2ts, then sequence of packets from the dependent view m2ts and so on...
(usually the base view m2ts contains the base H.264 video stream and audio streams, while the dependent view m2ts only contains the dependent H.264 stream)
The SSIF file contains the same packets those two files has, with those packets ordered to be suitable for linear read (to prevent excessive seeking when playing back 3D content, note that the disk itself has both the separate m2ts files and the SSIF point to the same sectors, so there is no duplicity there)
I began writing a multiplexer, but then I realized that Dolby Digital is limited to constant bitrate, so I just replaced one AC3 track with another track (of the same length and bitrate) without changing the size of the original ssif, so if your source already contains a constant bitrate audio track (that you don't need) and if you have a some programming skills, you could relatively easily perform such in-place replacement and write the new track instead. -
Next time you graverob a 3 year old thread, think about the fact that what was NOT possible 3 years ago might now be possible, but it doesn't negate what was written then, nor should the thread be updated without it being clear that time has passed. Otherwise, START A NEW THREAD!!
Takes all of 1 minute.
Also, even if Popcorn Hour & similar devices/apps CAN use raw SSIF files, doesn't mean that was how they were MEANT to be viewed.
Also, also, I think you better read up on the difference between "duplication" and "duplicity".
Scott -
You're absolutely right Scott,
In case anyone is interested, I completed writing my SSIF multiplexer, so now you can add as many audio tracks as you want:
Code:MP4Maker /mux /input=C:\Left.h264 /input=C:\Right.h264 /input=C:\Audio.ac3 /output=C:\output.ssif
How add a subtitle to a bluray disk and then convert from 50 GB to 25 GB
By siopilos in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Feb 2012, 10:49 -
Partial upconvert of DVD, add black border = Bluray
By HDTV's Frank in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Jun 2011, 02:15 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 12:29 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
add DVD subtitles to a bluray disk
By berendho in forum SubtitleReplies: 1Last Post: 30th Aug 2008, 18:30
