Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
Results 1 to 15 of 15
  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Picked one of these up today. Everything recognizes it except the software that came with it (WinTV 7)....
    Did a quick capture with VDub to HuffyUV - worked well but the audio sync was WAY off.....nice picture quality though.
    Did a quick capture with Magix Movie Edit - eyerything in sync with pretty nice picture quality.
    I think that was my very first capture with VDub so I most likely did something wrong.
    I also believe that me still having my Hauppauge PVR-350 in my computer is causing problems with WinTV not recognizing it.....not sure. WinTV "sees" both the 350 and the USB device but nothing shows on the screen.
    Any and all tips would be helpful and appreciated. I don't have any specific questions yet....still experimenting....just looking for advise.
    THANK YOU!!!!!
    Nov 2011
    Switzerland
    Hi, I'm looking to buy this USB capture device too. I have the PVR-150 right now, but I want to buy a new one that can capture with lagarith or huffyuv.
    I use VirtualDub for all my captures but the audio is never "Way off". Maybe a little but it's probably the bad video source I'm getting the video from (SVHS). By a little off, I mean like barely noticeable and it doesn't get worse throughout the video.
    Do you have PAL or NTSC
    Does your audio when you capture with virtual dub get more and more out of sync the longer the video is?
    Try capturing with the pvr350 and vdub togethr (huffyuv) and tell me if it's still out of sync.
    With which codec did you capture wen you captured using Magix Movie Edit?
    I don't think you did anything wrong while you were capturing with vdub since their's not much to do wrong:
    /Open VDub/Files --> Capture Avi/Files --> Set capture file/Video --> Video source (set to composite or s-video)/Video --> Compression(set codec you want)/Capture --> Capture Video/
    Nov 2011
    Switzerland
    Oh yeah, and never capture to a external usb stick or even hard drive just in case.
    And did you get droped frames while capturing with vdub (you can se at the bottom of vDub while capturing)?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I have mine set up for PAL right now. I'm capturing to an internal SATA hard drive. It works perfectly with Magix but still haven't figured out capturing with VDub.
    Nov 2011
    Switzerland
    since I was thinking buying this card and I use virtual dub it wouldn't be good if it's not possible to get it work with vdub.
    Try it the way I wrote it works.. thats how I do it and it works fine.
    Pleas tell me with which codec did you capture while using magix.
    Feb 2004
    Australia
    With which version of virtualdub ... there's an audio option for keep audio in sync which by default is checked ... clearing that option solved my sync issues with many capture devices over the years.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What are you talking about?
    CARD?
    My Hauppauge PVR-350 is a "card".
    My Hauppauge USB-Live 2 is not a card.
    The PVR-350 "card" is an MPEG2 capture card....and as far as I know there is no way to get it to capture anything else but MPEG2.
    Nov 2011
    Switzerland
    I made a mistake it's a usb capture device, sorry.
    "Did a quick capture with Magix Movie Edit - eyerything in sync with pretty nice picture quality."
    I'm asking which codec did you use with the USB live 2 whle using Magix Movie Edit.
    I know that you can only capture mpeg2 with the pvr cards. I have one.
    Aug 2006
    Look at https://forum.videohelp.com/threads/315378-need-help-with-ati-TV-wonder-650-USB-no-soun...=1#post1995236
    Although the capture device in question is not a USB-Live 2, the post above has some advice on which options to use with virtualdub when there are problems with the captured audio, and links to other posts with more general advice for capturing successfully with virtualdub.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    "did a quick capture with magix movie edit - eyerything in sync with pretty nice picture quality."
    i'm asking which codec did you use with the usb live 2 whle using magix movie edit.
    mpeg2
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Thank You....the settings in that thread worked perfectly. Audio is in perfect sync.
    Captured to HuffyUV, reopened in VDub and did some "border control", saved as HuffyUV again....encoded to MPEG2 with MainConcept:
    http://hotfile.com/dl/148164665/9586ed5/test.huffy_out.mpg.html
    Not bad for a mediocre VCR. I think the audio noises were my fault.....had the audio cables running all over and around possible disturbances(power cables etc etc).
    Jan 2009
    This is what I did for WinTV PVR USB2: Start, Run regedit hkey_local_machine\software\hauppauge\hcwTVWnd Live Preview change Value Data from 0 to 1 (default may have been 2, not sure based on my notes) I don't know if this will work for other Hauppauge devices, but if not you can make a note of what the setting was originally prior to changing it, and change it back if it doesn't work.
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Ummm.....what are you talking about?
    Jan 2009
    Lip sync prob w/capturing via WinTV, how to fix for that particular device via going into registry.
  15. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I don't capture with WinTV7 since it wont recognize both the USB2 and the old PVR-350. My lip-sync problems were with VirtualDub capturing with HuffyUV.
