The software title Video Redo has a function in it that seems unique, that it can edit out commercials from videos. Has anyone successfully used the software and done this? Was there anything else required when removing them? Is it pretty straight forward, or is there a trick to it, where you perhaps have to configure the software a certain way for it to detect the commercials in order to remove them? Also, is there any other software title that does the same thing?
One method is ... it detects the portion of Black between the TV show and the commercial ... but sometimes the Black portion is not there. Or is not there long enuff to be detected accurately.
I use my own eyes to see where to cut out the commercials ... I dont use it ... I do my own cut and remove ... sometimes I see a commercial I want to keep. -
I haven't tried VideoReDo's commercial removal feature. I don't trust automated commercial detection and removal to do a proper job, so I do it myself. There is other software that removes commercials. MC-TVConverter and MCEBuddy have the feature too, although I have not tried it. I did try Comskip at one point, but didn't like it.
Due to its superior ability to handle errors in video and audio streams, VideoReDo is the only editor I would recommend for editing TV captures from a TV card, or TS files captured from a DVR via firewire. -
Womble also has the same feature called blank fades or scene detection - it has the added feature of being able to configure the audio detection. At the end of the day it is probably quicker to do it manually. Personally I use ProjectX to remove commercials from off air digital tv so that subtitles remain in sync.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks for the suggestions, all! I was thinking that the program can't possibly remove all of the commercials, because like Lacywest said, it detects the black portion between the video content and the commercial, and sometimes it's just not long enough to detect, or there is some other problem of the software detecting it. I'll just use Movie Factory to remove the commercials manually. It will take longer, but they will for sure be removed.
Thanks again! -
I agree that Video Redo is a great editor but I also choose to edit commercials out manually. AVIDemux also has 'black fade' detection & you could try it if you need a semi-automatic feature. It'll take you to the next black portion & allow you to step forwards/backwards from that point to get the actual edit points you prefer.
Video Redo problems
By Phaneendra Rao in forum Authoring (DVD)Replies: 6Last Post: 25th Feb 2012, 03:32 -
Anyone used Redo backup??
By ranchhand in forum ComputerReplies: 5Last Post: 3rd Oct 2010, 00:11 -
AGK and Video-redo not recognizing my HDTV files...?
By OrangeTTT in forum Video ConversionReplies: 17Last Post: 10th Dec 2008, 02:34 -
GUI for DVD and Video Redo both crash Win2k
By Skarr11 in forum Authoring (DVD)Replies: 1Last Post: 20th Jul 2007, 18:02 -
Redo chapters in a DVD
By zakman in forum DVD RippingReplies: 1Last Post: 24th Jun 2007, 16:19
