  1. General
    Complete name : D:\imp\MKV\I know-1.mkv
    Format : Matroska
    File size : 3.08 GiB
    Duration : 1h 37mn
    Overall bit rate : 4 542 Kbps
    Encoded date : UTC 2012-02-24 17:03:32
    Writing application : mkvmerge v5.1.0 ('And so it goes') built on Nov 28 2011 23:58:28
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Muxing mode : Container profile=Unknown@3.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 37mn
    Nominal bit rate : 3 047 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Original frame rate : 23.976 fps
    Standard : NTSC
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.353
    Writing library : x264 core 112
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=3047 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    colour_primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    transfer_characteristics : BT.709-5, BT.1361
    matrix_coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : PCM
    Codec ID : A_PCM/INT/LIT
    Duration : 1h 37mn
    Bit rate mode : Constant
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    this is the detail of my video and audio file ,
    when i converting MKV to MP4 in format factory,
    format factory is hang,even cannot close the software,
    any solution ?
    "The Strongest people aren't always the people who win,but the people who don't give up when they lose"
    Try a mkv to mp4 tool like mkv2mp4 or rebox.net or gotsent.
    Or if you want to shrink try VidCoder or Handbrake.
  4. Thanks
  5. i use both
    but handbrake quality is good but take almost 4 hours,
    vidcoder quality is not up to the mark but fast encoding (less than 1 hour),
    so now i want more information about vidcoder, any hint..................
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Vidcoder is based on handbrake so you should get same quality. But they might use different default settings and x264 profiles.
    Try increase the video avg bitrate/bigger file size or use a lower constant quality value, and use a "slower" x264 preset for better quality. You find those settings under video in vidcoder.
    Screenshot:
  7. ok i try that but,
    i can't under stand advanced option
  8. Member Chef Goldblum's Avatar
    Feb 2012
    Planet Earth
    If you want to shrink the size of the mkv while converting you can use something like handbrake or vidcoder like Baldrick suggests. If you just want to change containers, use gotsent. It's easy to use, and you can just copy the video stream to the new MP4 instead of converting it. This process takes only a few minutes. Not like transcoding which takes hours in most cases.
