I have transferred some videotape to avi using AVS Video Recorder. When playing back video I notice that the audio is about a half second ahead of the video. This can be distracting on playback. I then convert AVI to M4V (to play on Iphone) using AVS Video Converter. There is no change in video/audio sync.
Is there adjustments I could make to sync the video and audio so it plays both in time?
Thank You,
Don Seddio
Please don't post same question in seveal threads. I deleted your other post.
Capture with something else? Virtualdub. -
Pretty much every A/V container has a setting to delay or advance the audio or video to sync them.
If it's just a constant shift, I'd listen to jagabo and look for software adjustments. If the audio gets more (or less) at of sync at different times, then it's caused by dropped/duplicated frames.
If your problem is dropped/duplicated frames, then use Virtualdub if you can. Go to Capture mode with File->Capture AVI and go to the "Capture timing options" with Capture->Timing. Leave EVERYTHING unchecked in the "Capture timing options" window except "Correct video timing for fewer frame drops/inserts." The resync mode should be "Sync audio to video by resampling the audio to a faster or slower rate," and the audio latency determination should be "Automatic." Everything else should be unchecked. Once you exit out of capture mode and exit out of Virtualdub without a crash, these settings should be saved for future use. They're somewhat unorthodox and different from the defaults, but they're by far the most reliable for me and another user (jmac). I never, ever, EVER have any audio sync problems.
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
Fix .mov where A/V in sync at beginning, ~1 sec offset at end?
By Grahamf in forum ffmpegX general discussionReplies: 3Last Post: 30th Mar 2011, 12:14 -
8 hours of MiniDV tape to DVD. Least painful method of transferring?
By Simmster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Nov 2009, 04:30 -
Problem Transferring Video Into Computer
By HarveyCee in forum EditingReplies: 1Last Post: 19th Aug 2008, 13:18
