Hi there,
Basically I'm having a bit of an issue capturing footage from quite an old Sony Handicam to my Mac.
It turns out the DV out port has broken but I still have an A/V out and USB port. Is there a way I can use either of these to capture the DV tape onto my mac?
I only have Adobe Premier pro and iMovie, so if I need other software, what would that be?
Help is much appreciated. I have a project due in asap and no idea how to fix my problem..
Moving you to our mac section.
I think you can only copy still images using the usb port and for the a/v port you need a capture device for you mac. -
Yeah, i think he is right, you could go AV out to a RCA-DV Converter and then into your mac. It works, but the converters will run you around $100
You can use an external analog to DV device like a Canopus/GV ADVC or ADC Pyro to Firewire.
Or you can use a Mac compatible analog capture device like Elgato (various) to USB2.
You won't get quality digital video out the USB port. Sony cams output webcam 320x240 quality.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
capturing quicktime on mac
By devdev in forum MacReplies: 2Last Post: 18th Nov 2010, 15:33 -
Mac question: Capturing YouTube from Cache?
By Littlebit in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 17:29 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Capturing Blu-ray onto a Mac
By MrBlueSky in forum MacReplies: 5Last Post: 15th Dec 2009, 02:32 -
video capturing from an xbox 360 to mac
By Aaron2123 in forum Capturing and VCRReplies: 1Last Post: 30th Nov 2009, 14:18
