When ripping extras smartripper fails to rip the sound. Any tips on this problem
Smart Ripper rips VOB files, and they are supposed to contain all the Audio part in them, I suggest you rip the VOB and check the INFO.TXT file that SR creates and see where the Audio is located, and then use DVD2AVI to select the correct Audio track.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
