More of a "WTF?" post than anything, but I'm curious if anyone else has mid-90s Fox Kids recordings they can check for the same anomaly. This particular tape was recorded from cable TV in 1995. I have a capture from a late 1997 tape that shows the same thing.
Attached video is compressed with Ut Video Codec. To inspect the sample:
The luma portion of the interlaced end credits move at full-rate, but the chroma is half-rate. This affects all of the programs and ads, not just this particular show. Chroma changes are sometimes split across scene changes. Recordings from different channels on the same tape are normal, and the rainbow pattern flashes at 60Hz, so I'd like to think we can rule out a capture problem.Code:AVISource("scrolling.avi").AssumeTFF() Bob() StackVertical(StackHorizontal(UtoY().Subtitle("UtoY"),VtoY().Subtitle("VtoY")))
I assume the small high-res portions in U and V are from incomplete Y/C separation.
	I haven't see the video yet (it's still downloading), but did you use UT Video Codec in YUY2 mode or YV12 mode? UT in YV12 mode defaults to progressive -- that would cause the symptom you're seeing.
 Got the file now... I see it's in ULY2 mode, 4:2:2. Any chance it was YV12 at some point?Last edited by jagabo; 23rd Feb 2012 at 22:30.
	Nah, I captured other parts of the tape in the same file and they're normal. It's only the stuff from this channel that's screwy.
	Amazon's manufactured-on-demand release of "The Amanda Show" suffers from the same issue.
 Code:FFVideoSource("TASD1-sample.mpg",cache=false) Bob() StackVertical(StackHorizontal(UtoY().Subtitle("UtoY"),VtoY().Subtitle("VtoY")))
	Is this PAL stuff? I know this sort of thing can happen to PAL footage that isn't edited correctly (don't retain the 4-field cadence required for complete color, IIRC).
	Native 60Hz. I have digital TV recordings with full chroma (but the bitrate sucks).
  Chroma-Keyed Video with Transparent Background on a WebsiteBy ambassador in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2008, 22:50
  Vegas adding video overlays using chroma keyBy SearchQuality in forum EditingReplies: 12Last Post: 14th Dec 2007, 18:12
  Video Tutorial: Chroma Keying in FCPBy IceflowStudios in forum User guidesReplies: 0Last Post: 14th Dec 2007, 17:42
  Need help chroma keying with Fusion (and other software) for Flash video.By OM2 in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2007, 21:07
  Is There a Easy way to do Chroma Keying with Video?By Datahead in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 21:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
