    Jul 2008
    Tried to get as much info into the title
    Basically that's it. I'm using AVCHD to convert a 1080p MP4 clip to blu-ray format and the conversion initially works fine. If I play the blu-ray disk structure in VLC, it plays fine as well - black bars on the top and bottom and the correct aspect ratio.
    I then burn it to a BD-R using imgburn and when I put it in my blu-ray player and play it the picture is basically panned and scanned and looks horribly stretched. the black bars are gone !
    it's really starting to frustrate me and i've wasted 3 blank bluray discs already so any help would be most welcome, thankyou.
    Do you mean AVCHDCoder?
    You could try bdtoavchd. And burn on a bdre.
    Jul 2008
    sorry that would help wouldn't it - i'm using multiAVCHD
  4. did you check the display settings on the tv or player ? maybe you have it set to pan & scan or zoom or some AR setting ?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    I guess you know that multiavchd hasn't been updated for a long time now....so I would look for other blu-ray converters/authoring solutions.
    Try also play the blu-ray on your computer with powerdvd or tmt and see how it looks like. Not just vlc.
    Jul 2008
    i didn't know multiavchd hasn't been updated, no. the screen format on the BR player is "original" and the aspect ratio is set to "letter box"
    tv type is 16:9
    cinema conversion is "auto"
    (this is a sony model..)
    all of the other screen settings are set to auto
    Jul 2008
    Problem solved
    In the transcode option, there's a resize and uncrop dropbox. The uncrop dropbox was always 1920x1080 but the resize box was 1920x900 (no change). I changed that to 1920x800 instead of the one with (no change) and re-transcoded it and it worked!
    burnt the film to a BD-R and played it on my TV and it worked fine - aspect ratio was bang on
  8. Member JimmyJoeBob's Avatar
    Oct 2005
    Gun Barrel City, TX
    AVCHDCoder will do it for you automatically no matter what the original was. Set and forget. Simple to use.
