system...ATI AIW 8500DV...ASUS PB4 board....80 gig HD...all works well...what I'm trying to accomplish is to put some VHS tapes onto a cd. Using Ulead 5...I am able to record to hard drive from VHS, thru my DV camcoder. However when setting up Ulead, it asks me for a template. I have heard that I am capturing too high of a resolution. Even when I play it on full screen it is fuzzy. Should my template be AVI..MPEG?...720X360...240X120.????. desperately confused! Also remember that I am trying to put this to a VCD format....What encoder should I use and to what format. Any help will be greatly appreciated.![]()
Well, VHS is 320x240 resolution... you should capture right into VCD compliant template (352x240 for NTSC or 352x288 for PAL), but you may try capturing 352x480 and afterwards, resizing into 352x240 in TMPGEnc.
That's a beginning.
Fredİ -
Thanks fred....however I'm laughing over here with your reply...Thats a beginning. Ain't that the truth....
I dont know if I make me understood well... thats because I am from Brazil and speak portuguese...
Help with VHS Capturing Project
By jrodefeld in forum Capturing and VCRReplies: 3Last Post: 20th Aug 2011, 00:05 -
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
Capturing VHS with MEncoder (Help)
By the98 in forum Capturing and VCRReplies: 10Last Post: 9th Mar 2010, 11:14 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32
