I'm looking for software that will convert .264 video format, not H.264! It's video from a security system and I can't find anything that will use this format, or even convert this format to AVI so I'm looking for software to convert .264 to avi. Thanks.
Results 1 to 13 of 13
.264 is H.264
Security cams conserve disk space by recording fewer frames per second usually with motion detection to separate normal noise from intruder detection. In other words they optimize the format to the task. The manufacturers of these devices have the option to make the resulting file playable as h.264 sped up or they can add various proprietary encryption to force you to use their software for playback.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Well I figured a few things out. One of them is always check the CD that came with the security system, it may have the proper software with it. Thanks!
I also found something else out, the supplied software doesn't work on my computer. I tried VirtualDub and Avidemux with no success. What software is the best to convert h.264 to AVI?
http://www.thinkcctvsystems.com/store/cms.php?id_cms=9
Both apps work well under win 7 64bit ... and the converter can handle files other converters can not handle.
And it's raw .264, not h.264 -
Security cameras often use non standard containers, and/or obfuscation, and/or encryption. Don't count on anything other than the software that comes with the camera to work with the video.
Check your .264 files with MediaInfo. Does it show AVC video? Can VLC play the files? Try using Mmg or Yamb to mux the files into an MKV or MP4 container. After that any media player should be able to play it -- if the video is really a plain h.264 stream. -
As you've been told, these are the raw video. Not in any container like mkv or mp4 for example. You can try avctoavi to convert without re-encoding the video. Simply changing the file extension to .avi also may work. Make sure that you are really changing the extension and not just adding to the filename.
I had same problem from my CCTV and found today this site the converter was free & worked (it is the 2nd download on the page)
I have spent weeks trying different things and have no tech experience...just a housewife and this works...hope will do for others. -
btw. uploading a short clip might help others to figure out what sort of video you really have,..
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Help with H.264 questions, Choosing format for mastering, etc.
By RainMotorsports in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2011, 06:03 -
Encode my H.264/AC3 .M2TS HD PVR video to Xbox friendly format?
By hopeSOLO in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 12:29 -
file format for storing video files (wmv or h.264)
By the_shyguy in forum Video ConversionReplies: 24Last Post: 10th May 2010, 01:21 -
converting Format 35 Youtube video to H.264 on Mac for iPod viewing
By Anonymous85454 in forum MacReplies: 12Last Post: 31st May 2009, 00:33
