    Sep 2006
    I have a 1080p video that plays on my PS3 with audio only and a black screen. I tried playing the video on my Xbox 360 and the 360 wouldn't play it at all, just hangs on a black screen.
    MediaInfo:
    General
    Complete name : 1080pVideo.mp4
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 2.94 GiB
    Duration : 2h 6mn
    Overall bit rate : 3 332 Kbps
    Encoded date : UTC 2012-02-19 11:27:20
    Tagged date : UTC 2012-02-19 11:27:20
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 6 frames
    Format settings, GOP : M=4, N=16
    Codec ID : avc1
    Duration : 2h 6mn
    Bit rate mode : Variable
    Bit rate : 3 009 Kbps
    Maximum bit rate : 24.8 Mbps
    Width : 1 920 pixels
    Height : 1 072 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.061
    Stream size : 2.66 GiB (90%)
    Writing library : x264 core 120 r2164 da19765
    Encoding settings : cabac=1 / ref=6 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3009 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.90
    Encoded date : UTC 2012-02-19 05:42:48
    Tagged date : UTC 2012-02-19 11:30:54
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : ac-3
    Duration : 2h 6mn
    Bit rate mode : Constant
    Bit rate : 320 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 289 MiB (10%)
    Title : ā
    Language : English
    Encoded date : UTC 2012-02-19 11:27:27
    do u teevee?
    I'm moving you to our video conversion section as this is not any blu-ray.
  3. I'm pretty sure 6 reference frames is too much for the PS3. And profile High@L5.1. It may not like the resolution either. Yes, a lot of players don't like AC3 in MP4 (it was officially added to the spec a few years ago but many players have not been updated).
    You can try just changing the profile to High@L4.1. Still, when it hits a section with 6 reference frames it will have problems.
    Sep 2006
    The audio plays fine on the PS3, I just get no picture.
    do u teevee?
  5. Did you try changing the profile? Use h.264 Level Editor.
    https://www.videohelp.com/tools/H264-AVC-Level-Editor
    Sep 2006
    Changed it to 4.1 as suggested, still plays the audio with a black screen.
    do u teevee?
  7. Then you will probably have to reencode with settings that the PS3 and/or XBOX360 supports.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    ps3 is also bad with video with peaks over 15mbps and i don't think it will play anything with b_pyramids. re-encoding is the only way to get that one to play.
