I've got a 4.1Gb mpg file ripped from a DVD.
Video codec is mpeg2.
Now I want to downsize it to about 1.4Gb.
So I would like to know what options I have to this with the least loss of quality. I know some quality loss cannot be avoided but I want it to be as little as possible.
I prefer final codec to be H246, if possible.
The tools can be free or not.
I'd appreciate any advice.
Thanx
Results 1 to 12 of 12
It depends somewhat on what your media player can support but for me I would convert to MKV
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Like Kerry56 said, Handbrake is an easy but also efficient tool. If you don't mind complexity you might also try meGUI. It gives somewhat more options to influence your encoding outcome.
Regarding Baldrick's post...VidCoder is basically as good as Handbrake. But for me, I haven't found a way to encode files with it using constant frame-rate. It always gave variable FR.Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
+1 on VidCoder. It is handbrake. The developer just wrote a different, somewhat streamlined interface. It's easier for newbies, though handbrake was already better in that respect from other good converters because only outputting mp4 and mkv makes the options a lot less daunting to learn.
I prefer the 2 pass target file size setting. It's given me the most consistently reliable high quality output.
For minimum quality loss you want at least 1 gig per hour of source video file size target. I don't remember just off the top of my head how long a 4.1G mpeg2 file from a DVD is but 1.4G would be less than 90 min from that reckoning.
A setting of 1G per hour doesn't give you perfection ... you won't get that with any compression method. But it's very acceptable. -
Handbrake is my choice for doing this pretty simply. I'd go with constant quality vs 2 pass because it takes less time and the results will probably be pretty much identical with a DVD rip. As far as file type goes, MP4 is less "cool" but more widely supported than MKV, and it's what I always use.
I tried to use HandBrake because it seemed to be what I was looking for.
In the videohelp tools there is a screenshot loaded and it shows that you can chose the target size of the output file; and that was what I wanted.
However, the version that I downloaded there is no such option in the Video section, under Quality.
The options you can chose from are only "Constant Quality" and "Avg Bitrate", that's all.
So I wonder why is this difference... -
With constant quality, you can choose the quality of the encoding but you cannot know what will be the size of the output file before you have made it !
With average bit rate you can use the formula:
Averagebitrate = filesize / time
but remember bit rates are usually given in bit per second , file sizes in bytes and time in minutes.
One byte (B) is 8 bits (b) ,and one minute (mn) is 60 seconds (s) !
Remember audio also needs some bit rate and multiplexing will also you some space more.
For best quality one should always use variable bit rate . Average bit rate must be less than maximum bit rate or you will just get constant bit rate ! -
The new version of Handbrake doesn't support target file size anymore. That bugged me at first but I've adapted. Itl tells you what the file size will be though, as I remember. I've been experimenting with constant quality mode and advanced settings lately.
Anyway, I think the newest version of handbrake is better enough to make adapting worthwhile. If you really want target file size mode use vidcoder, which uses the last version of handbrake as its engine. The user interface is easier to get around too.
If you're a newbie the more advanced settings, which you'll find discussed often here, may be a bit confusing. The handbrake docs for the basic stuff is excellent ... better than many programs you pay for. But for advanced options they dump you straight into the real video geek stuff. And it's complex.
What I'd suggest for a start with handbrake or vidcoder is that you always use the high profile unless you want to rip to a mobile device. That way you can get 8x8 DCT, which is essential for high quality. Unfortunately the default profile upon startup is the standard profile.
If you want to try advanced settings, the handbrake docs will point you to the .264 options page on the mplayer site. There are some useful settings there but you'll have to play with it a bit because the nomenclature isn't 100% the same.
I guess I am turning into a video geek. Somewhat reluctantly. Past a certain point there doesn't seem to be much choice. -
Wow, that surprises me a little.
Personally I rarely use file size based encoding myself as there's more reasons not to than there are for doing so, but there are instances where you do need to encode something to a fixed output size. It seems like an odd feature to drop completely.
I use MeGUI myself, but I'd also recommend FFcoder, HDConvertTox or Ripbot to the OP as programs to try.
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 02:09 -
How to burn 1920x1080 mpg to dvd without loss of quality?
By ABUELLO in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2013, 14:48 -
MPG editing without quality loss?
By spup345 in forum EditingReplies: 7Last Post: 20th Jan 2010, 16:15 -
Large size difference in mov and mpg, no apparent loss of quality.
By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 09:19 -
Best Program To Downsize AVI With Little Quality Loss?
By blazin-j in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2008, 22:30
