Hi
I am having a problem playing mkv files on my blu ray via both a seagate 1 TB HDD and a core 60GB. I used to use MKVMERGE, and didn't have a problem,however in the last 2 months the blu ray, although seeing the split files (both below 4GB), they are reading as 0.00, rather than the running time. I know it is a problem with the bluray because I can use the core going through a sumvision HD cyclone micro 2 on a different t.v. I have tried MKV2VOB, but have the same problem. I also tried comgenie's awesome file splitter, however that split the file into an MKV and one with an extension called .part, which I could not play. Can anyone advise me of a programme for splitting files that will work? Or is there a setting within the blu ray I could have inadvertently changed by mistake?
Julie
I guess you have disabled header compression(file->options) in mkvmergegui?
You can try split with something else like solveigmm avi trimmer and see how it works. -
Hi Baldrick
Thanks for your response, I have just ticked "disable header compression" within MKVmergeGUI, will let you know whether it makes any difference.
Julie -
This thread just saddens me. I swear if some damn TV or BD player made people chop off a finger to play a freakin' file there are plenty of people who would do it without question.
Julie - Just get yourself a good media player like a Western Digital or something similar. Splitting files so your BD player can handle them is bs. However, to be fair "header compression" won't work on anything but a PC. It's a great question as to why so many people continue to use it when it introduces compatibility problems. -
depending on WHERE you are going to play the split files (blurays, tvs, especially), you MIGHT have problems with header compression. remove compression in GUI (older versions) or at command line:
mkvmerge --split 1G --compression 0:none --compression 1:none --clusters-in-meta-seek -o "output.mkv" "input.mkv".
this command will split the input.mkv file into 1GB segments input-001.mkv, input-002.mkv, etc.
Blu-Ray Turns off when playing MKV file
By Bobor in forum Newbie / General discussionsReplies: 9Last Post: 4th Mar 2012, 07:42 -
Playing MKV - H264 in samsung blu-ray BD-C5300
By cwebdesign in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Dec 2010, 15:42 -
Problems with Blu-Ray to MKV
By leejayd in forum Blu-ray RippingReplies: 1Last Post: 24th Apr 2010, 07:30 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 11:26 -
mkv to m2ts playing on my blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2010, 17:24
