I've been using Nandub v1.0rc2 for several months now, and started getting this error when I try to capture video: "Access violation in capture routine. Virtualdub has intercepted a crash condition in one of its routines. You should save remaining data and exit Virtualdub immediately." I have had Virtualdub installed since I installed Nandub! Does anyone know what is causing this and how I can fix it?
Mucho Gracias!!
JGIBSON65... do not use nandub for capturing purposes. it is used for encoding sbc ONLY. go back to vdub. install vdub and nandub into different folders in order to use them both for their respected purposes.
later bater. deltaboy
nandub 1.0rc2 slow seeking
By worm9110 in forum EditingReplies: 1Last Post: 28th Jul 2011, 11:07 -
Encoder using Nandub
By PageDown in forum Video ConversionReplies: 5Last Post: 20th Nov 2010, 22:18 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33
