I'm trying to convert the output files from AnyDVDHD to an MP4 for Iron Man 2. I've been using the methods I am for about 50 Blu Rays so far with no issues, but I cannot get this one to work for some reason.
I copied the disc with AnyDVDHD, and that went fine, but when I try to load the .mt2s files into Ripbot, I get an error during demuxing. Here's what it says:
eac3to v3.24
command line: "D:\Desktop\Sync\Ripbot264 1.17\Tools\eac3to\eac3to.exe" "E:\IRON_MAN_2_D1_AC\" 1) 2: "C:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "C:\Temp\RipBot264temp\job1\audio_English.dtsma.w6 4" -down16 1: "C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 2 video tracks, 6 audio tracks, 8 subtitle tracks, 0:22:21, 24p /1.001
1: Chapters, 17 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: h264/AVC, 480p24 /1.001 (20:11)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
5: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
6: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
7: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
8: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
9: AC3, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB
10: Subtitle (PGS), English
11: Subtitle (PGS), English
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
14: Subtitle (PGS), Portuguese
15: Subtitle (PGS), French
16: Subtitle (PGS), Spanish
17: Subtitle (PGS), Portuguese
Creating file "C:\Temp\RipBot264temp\job1\chapters.txt"...
[v02] Extracting video track number 2...
[v02] Muxing video to Matroska...
[a04] Extracting audio track number 4...
[a04] Decoding with ArcSoft DTS Decoder...
[a04] Reducing depth from 24 to 16 bits...
[a04] Writing W64...
[a04] Creating file "C:\Temp\RipBot264temp\job1\audio_English.dtsma.w6 4"...
[v02] [0:22:21] The source file seems to be damaged (discontinuity). <WARNING>
[a04] [0:22:21] The source file seems to be damaged (discontinuity). <WARNING>
[v02] [0:22:21] Detected PTS break, increasing PTS by 41.7ms... <WARNING>
[a04] [0:22:21] Detected PTS break, increasing PTS by 5.3ms... <WARNING>
[v02] [0:22:22] The source file seems to be damaged (sync byte missing). <WARNING>
[a04] [0:22:22] The source file seems to be damaged (sync byte missing). <WARNING>
[a04] [0:22:22] The source file seems to be damaged (discontinuity). <WARNING>
[v02] [0:22:22] The source file seems to be damaged (discontinuity). <WARNING>
[v02] [0:22:22] The source file seems to be damaged (transport error indicated). <WARNING>
[a04] The ArcSoft DTS Decoder reported an error while decoding. <ERROR>
Aborted at file position 6722877440. <ERROR>
I've tried to re rip the Blu Ray... I've put it on multiple drives, even tried it on another PC. No luck so far.
I'm using Rpibot264 v1.17 and AnyDVDHD v6.9.10 and I have no idea how to fix this. Please help, this is one I'd really like to have in my collection!
I've experienced similar behavior with other discs. Haven't found an explanation so far. I then copied the disc (full copy) with DVDFab, and it worked just fine. Maybe this is an option for you too. Keep in mind not to use the free DVD HD Decrypter. It may not work because it's about 6 month slow compared to the full DVDFab. So better take the full DVDFab trial. I did and was very much content. And considered it worth buying...
Also you might try Handbrake for conversion, or BDtoAVCHD.Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
Well, handbake did the encoding...
But the output file was only 12 min long and was completely fubar. I guess I'll just try to snag a good torrent.
Avatar Extended Edition forced subtitles issue with RipBot264
By DrPreston in forum SubtitleReplies: 16Last Post: 24th May 2013, 16:51 -
Frustrating issue with Ripbot264
By Beast Lee in forum Blu-ray RippingReplies: 1Last Post: 26th May 2011, 14:55 -
RipBot264 error before conversion - an object or file not found
By Obamargarine in forum Blu-ray RippingReplies: 3Last Post: 15th Feb 2009, 11:47 -
Video Conversion issue
By BIFFtheSTIFF in forum Video ConversionReplies: 3Last Post: 25th Nov 2008, 08:51 -
Conversion Issue
By yousif5877 in forum Video ConversionReplies: 4Last Post: 13th Feb 2008, 04:16
