Page 4 of 4
FirstFirst ... 2 3 4
Results 91 to 98 of 98
  1. Banned
    New York, US
    Looks interesting, 2B. I'm saving that one to look into later, got a few crappy videos I can try. Thanks for sharing.
  2. Banned
    Dec 2010
    New York
    Excuse the noobish question David, but is that an actual script or just instructions on what settings to use in your script?
  3. Banned
    New York, US
    It's an adaptation of part of a popular video restoration script. Check the link in 2Bdecided's post to the discussion of Video Fred's complete script (several versions exist).
  4. Member 2Bdecided's Avatar
    Nov 2007
    ...and thankfully you can download the entire plugins package in one go from that thread.
    unclesoob, if you have all the required plugins, you'll find that just adding a source statement (AVIsource, or whatever) at the top of the code I posted will make it a complete script.
    Cheers,
    David.
  5. Banned
    Dec 2010
    New York
    David, are we pals?
  6. Banned
    Dec 2010
    New York
    By the way, Sanlyn (and others):
    I just did a sample of my toon with MCTDN, threw in a little Ttempsmooth (but BEFORE the MCTDN script, not after) I did this so that the masking and other components in the MCTDN script can also protect my video from the ghosting and artifacts that Ttempsmooth can cause at slightly high settings. Does this make sense?
    Anyway, I gotta say dudes this script is NO JOKE. I did a sample with low settings and then gave it to Neat Video for a finishing touch on those really noisy sources. SUPERB. Slow as hell but worth the wait. I knew my trouble would be worth it.
  7. Member 2Bdecided's Avatar
    Nov 2007
    Originally Posted by unclescoob View Post
    David, are we pals?
    Only if you stop offering to pay me for my services.
    You don't know you're born. I've run 0.5fps AVIsynth scripts. Days to process a 3 minute clip. Though at the time people would swear it was magic. e.g. 50i > 24p indistinguishable from native 24p.
    Cheers,
    David.
  8. Banned
    New York, US
    Not really. If you look at the chart of heavier settings in MCTemporalDenoise doc you'll see that it runs temporal smoothers internally anyway, like TTempsmooth, GradFun2DBmod, and FFT3D. I didn't see ghosting except some in the source that likely came from generation-copy damage or tape playback, but MCTD didn't cause it. Maybe you can post a sample capture frame to show us what you mean.
