  1. Hi,
    I'm looking for a DVD Changers that are hackable (Macrovision, Region, etc.). It's hard to weed through the list not knowing what is a changer and what is not. Please post all make/models that you're aware of.
    Thanks,
    JAMES.
  2. The GE 3-disk changer, which you can find at Wal-Mart, is hackable with a firmware patch you can download. I believe the model number is GE-5803P and there are links in the DVD players section on the VCDHelp website. I have this player, but I'm not at home now to verify the part number. It's a Shinco-based model, so it's hackable, unlike the GE 5-disk model, which is NOT hackable (as far as I know). It's a great region-free DVD player, but it could be helped in the MP3/VCD department, but those formats work good enough. It also converts PAL to NTSC! Good luck...
    --Porfirio
