I converted an NTSC DVD to .avi and I face problems with audio out of sync. As I was searching for a reason I noticed that the DVD source was in 29970 fps but Megui converted the output .avi file to 23.976 fps.
Can Somebody help me on how to maintain the same fps as the DVD source? (I guess that this is the problem for the audio being out of sync).
Thanks in advance.
My advice will be to first check if the sync issue is caused by the fps of the video or a simple delay.
Check if the delay of the audio is consistent or progressive throughout the video. -
If you are sure the delay is consistent and does not increase throughout the video then you can try playing around with the delay of the audio.
Normally MeGUI would have got the correct delay settings for the audio when you index the .VOB file.
O.K. I understood but I have audio delay in the output, not the DVD source. When the audio is extracted from the source there is no delay.
furthermore, I tried to convert the output .avi file to the same fps as the source (29.970 fps). But after conversion the video duration was 1h 15 min whereas the source video duration is 1h 34min.Last edited by gartzo; 21st Feb 2012 at 07:19.
My fault, the audio delay is not consistent. When the movie starts the audio is in perfect sync with the video but halfway through the movie appears an audio delay.
Any ideas???Last edited by gartzo; 23rd Feb 2012 at 06:19.
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 13:52 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
AC3 AVI -> DVD with CuCuSoft audio problem
By carlos305 in forum Video ConversionReplies: 3Last Post: 23rd Aug 2007, 02:19 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29 -
DVD to AVI[Xvid] Audio Problem
By Kapnos in forum DVD RippingReplies: 14Last Post: 20th May 2007, 00:46
