I recently purchased a DVD burner with my new Dell system, and it kicks ass. But unfortunately all I have to burn on is one DVD-RW that came with my system, and being from Wyoming I have not been able to locate DVD-Rs or DVD RWs. I was wondering what people out there use, and what is the biggest DVDR or RW I can get. I know standard is 4.7 gig, but I need something bigger for direct copying. Thankx
Results 1 to 10 of 10
Wow Dude, Wow.
Well, DVD discs dont come larger than waht u have, unless u
purchase a double sided disc. So for any projects u might have,
over 4.7gb, you will have to split over more than one disc/side.
I personally use discs from www.cdrecordables.com, and have
not had any problems at all using them on my Pioneer A03,
and my Toshiba standalone unit. Some folks have had problems
with them, so check around.
As i said they work for me, and they are only $2.00 each, easily
the cheapest you can get.
Winston -
i suggest that you also get the free Image Drive from Nero so u can test ur DVD's
I suggest keeping a few dvd-rw's to do your test burns for playback to see if all is well, and then burning to dvd-r if it's all good for final permanant burn.
Hi
This one is for winman42!!!
The site that you mention doews not exist... are you sure about the name???
Pls post again the name of the site!!! that price of DVDr is incradable!!!
SpeeD -
Speed, sorry for the typo, the URL is www.cdrecordable.com
Try this link for the discs i was referring to..which are actually
$2.39 each. Try one, and see if they work for you. I've had no problem
at all with my players.
http://store.yahoo.com/cd-recordable-dot-com/viv47120mind.html
Winston -
Thanks man!
Itīs really unbealivable!!!!! $2 or $2.50 fos a DVD very nice!!!!
Does anyone knows how many time does it takes to record a full DVD-r (2x) im thinking of buyning one...
Thnkīs guys and thnks winman 42
SpeeD -
What do u mean 'how many times' does it take?
I assume u wanna know how MUCH time it takes to
burn a DVD? I've never paid attention.
Win -
Here is some of the best deals I've found on dvd media. Hope this helps guys.
Zorin
http://www.supermediastore.com/dvdmedia.html
http://dvdr4less.com/cgi-bin/smart_cart2.cgi
http://www.cd-recordable.com/ -
If you are in the uk try:
http://www.bigpockets.co.uk
http://www.svpcommunications.co.uk
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 20:33 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
