Page 2 of 2
FirstFirst 1 2
Results 31 to 35 of 35
    May 2013
    Staffordshire
    Thank you for the detailed explanation.
    Sorry if this is a stupid question.
    Microsoft TV subtitles Decoder filter is a one-way in filter. How do you use that to display subtitles on GraphEdit?
    What filter do you use for exporting subtitles?
    Aug 2006
    I don't know the answer to that question.
    I replaced the Microsoft TV Subtitles Decoder filter with the Dump filter to try to capture data from the DVR-4 pin.
    May 2013
    Staffordshire
    Thank you so much. Once I am able to extract the subtitles, I am going to reveal the method here.
    May 2013
    Staffordshire
    Hello
    I am writing to report that I am able to process WTV file with the subtitle stream although I found out Teletext is not extractable, because it is pixel based captions.
    I spent weeks on studying DirectShow and media foundation programming which turned out to be futile.
    I simply used FFMPEG to compress and converted caption streams by using
    This is the sample wtv file I have done.
    ffmpeg -I "input.wtv" -map 0:1(video stream) -map 0:2(audio stream) -map 0:3 -c:v libx264 (mp4 codec) -c:a:0 libmp3lame (mp3 codec) -c: s copy "output.mkv"
    or you can export only the caption stream by
    ffmpeg -I "input.wtv" -map 0:3 -c: s copy "output.mkv"
    It seems that the mkv format is the only format which carries subtitle streams.
    I will try to create some program using pattern recognition to convert WTV captions to srt. I will post it here.
  5. dvb subtitles in ffmpeg.
    try this: -vcodec (whatever you want) -acodec (whatever you want) -scodec dvdsub whateveryouwant.mkv
