Hi I've this script which adds subtitles in any video by setting markers and then running this script :
// Subtitle generator by !Rocky
// modified by Colin Harman ( http://colinharman.com/ ) to work on a Mac
// Save this code as
// "subtitles.jsx"
// Create a text file with your subtitles.
// Each line of text is one on-screen line.
// To have several lines on-screen at the same time,
// simply separate them with a pipe ( | ) character.
// eg "Character 1 talks|Character 2 interrupts"
// Create a new text layer in your comp, adjust its position,
// make sure the text's centered, so it looks nice
// Add markers (Numpad *) where each subtitle line must be shown/hidden.
// With the text layer selected, run the script, and select the subtitles file.
// Enjoy!
function makeSubs() {
var layer = app.project.activeItem.selectedLayers[0];
if (layer.property("sourceText") != null) {
var textFile = File.openDialog("Select a text file to open.", "");
if (textFile != null) {
var textLines = new Array();
textFile.open("r", "TEXT", "????");
while (!textFile.eof)
textLines[textLines.length] = textFile.readln();
textFile.close();
var sourceText = layer.property("sourceText");
var markers = layer.property("marker");
for (var i = sourceText.numKeys; i >= 1; i--)
sourceText.removeKey(i);
var line = 0;
var subTime, subText;
for (var i = 1; i <= markers.numKeys; i++) {
subTime = markers.keyTime(i);
sourceText.setValueAtTime(0, " ");
if ((i % 2) == 0) {
subText = " ";
else {
subText = textLines[line].replace("|", "\x0d\x0a");
line++;
sourceText.setValueAtTime(subTime, new TextDocument(subText));
makeSubs();
it works really well on adobe after effects cs5 but I want someone to edit it so I don't have to add markers to hide subtitles it's very annoying to add subtitles like this way for example : Now I have to press Num* to show subtitles and then again Num* to hide and vice versa..
All I want is to only press Num* to show subtitles and when I press Num* again it should show next line in .txt file , and auto hiding previous line. So it will be very easy to add subtitles like this..
can someone modify this ?
Thanks in advance.
Results 1 to 1 of 1
Animate and Subtitle Script
By sambat in forum Video ConversionReplies: 4Last Post: 18th Jun 2010, 12:17 -
Help with editing and effects
By coppermouse in forum EditingReplies: 4Last Post: 19th Jan 2010, 16:28 -
AVS script and Subtitle Workshop
By sambat in forum SubtitleReplies: 3Last Post: 19th Apr 2009, 10:20 -
Editing and Effects
By moviedude21 in forum EditingReplies: 2Last Post: 8th Apr 2009, 09:36 -
Maybe Off Topic but how do you write a script/subtitle?
By Han Solo1 in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 10:18
