Hi![]()
Just the other Day I dot really frustrated.![]()
I used DVD2SVCD Program For the Matrix
it took dvd2svcd 14 hours to complete the matrix On just 2 CD.
The quality was satisfying to my taste (some may say I have none) as I managed
to squeeze 132 minutes of it.
well this part was not the part that gave me that bad feeling.
it was that thing , when Morpheus says to Neo: "She told me, I would find th..." and cut!!!
just then and there, in the middle of the sentence, the movie was cut.![]()
this made me think.![]()
and now I ask dvd2svcd (in the bitrate menu) to encode the video on a 795MB or 790MB minute CD
instead of 800MB as I used to do.
that gave me a range of about 1 minute cut either backwards or forwards.
now I have another problem.![]()
I use trial and error, to cut the movie on the right spot that the MB-range allows me.
sometimes I will mux&cut a few times until I am satisfied with the result.
is there a way, to know before cutting, when in time range, the movie will be cut by the MB range.
what i mean is, can i know before cutting what minute or second will it be cut on,
when cutting (for instance) on the 791MB or on the 793.
-or-![]()
is there a way to know what frame number sits on the exact MB instead of time?
thanks.![]()
Results 1 to 1 of 1
Avidemux - Why is there pixelation from stream movie?
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2012, 10:20 -
Cutting out a section of a movie
By hardy in forum Newbie / General discussionsReplies: 7Last Post: 7th May 2010, 09:17 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 11:20 -
Cutting out spaces between movie files
By demonwarrior in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2007, 08:32 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
