  1. which programs are able to play TSV files and which ones can convert it? For keeping the quality of the original file, which format is the best (arquive in DVD). Thank you for the help.
    Oct 2005
    666th portal
    tsv files are "tab separated value" database files. try to be more specific. if the are supposed to be video how did you make them and with what?
  3. This format is the format of the video recorded by equipment peekton 500. Transport stream format (*tsv). Can only be read in the equipment but if I choose to record as .mpg, subtitles can not be recorded... tnks!
  4. You might try VLC, or ffmpeg/ffplay, or mplayer/mencoder
    What does mediainfo (view=>text) say about the file ?
    Usually there are mulitple issues with proprietary formats. If you upload a small sample you might get better input
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    sorry it seems to be some machine sold only in france and i can't read a manual in french.
    if nothing can play the tsv files the mpg version is the best you are going to get.
  6. indeed, it is a french machine. What is strange is that, I have the possibility to choose the record format: TS or mpg. But when recorded, it is TSV...
    I tried FormatFactory program to convert to MP4; after 12 hours converting, a error message.
    Now I will try small records and the VLC as suggested.
    So, about the mediainfo, i renamed the file to TS instead of TSV and I could have:
    General
    Complete name : C:\Users\Elbia\Desktop\Films\PVR\20120218_212846AR TE HD\20120218_212846ARTE HD.ts
    Format : MPEG-TS
    File size : 2.57 GiB
    Duration : 37mn 44s
    Overall bit rate : 9 731 Kbps
    Video
    Menu ID : 1031 (0x407)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=4, N=32
    Codec ID : 27
    Duration : 37mn 44s
    Bit rate : 8 992 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.173
    Stream size : 2.37 GiB (92%)
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 37mn 44s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : -741ms
    Stream size : 69.1 MiB (3%)
    Language : French
    Text
    Format : DVB Subtitle
    Codec ID : 6
    Language : French
    Menu
    Duration : 37mn 44s
    List : 720 (0x2D0) (AVC) / 730 (0x2DA) (MPEG Audio, French) / 742 (0x2E6) (DVB Subtitle, French)
    Language : / French / French
    Feb 2018
    Brisbane
    TSV files partially solved
    I got mine from a hd Hisense TV
    Can play them using media player or KLM or SMPlayer v18.2.0
    VLC will not do it
    renaming works also but not required
    Feb 2018
    Brisbane
    I have also tested the above on VISTA and SM player works. Although if you
    dpn't change the TSV to ts they look like NOTEPAD file when you click
    on them. With Icaros setup you get thumbnails as TS. And you can
    see what you're doing.
