Hi,
Can any one help me how to convert video files to frames(motion not still) using adobe premier?
I need the converted files to load onto my camera settings in Houdini to use as a back ground of my 3 D obj.
I eventually need to render it and out put to various format to play it with high res.
I'd appreciate it if any one can show me step by step using example video or files.
Please use the attached mp4 file if you can. Thanks
Steve
Results 1 to 12 of 12
Clarify what do you mean "motion not still" ?how to convert video files to frames(motion not still)
Individual Frames are still - they represent a moment in time . Did you mean an image sequence ? like png or tiff ? -
I still don't understand your question ?
what format ?
use adobe media encoder
if you want a sequence of still images (frames), checkmark the image sequence box
if you want a video, then select a video format -
I have mp4 original to be converted to frames of mov or whatever.
I use adobe premier. -
houdini supports tiff, so convert it to tiff sequence using adobe media encoder (comes with premiere)
http://www.sidefx.com/docs/houdini9.5/io/formats/
http://www.sidefx.com/docs/houdini9.5/io/formats/image_formats -
I guess I nee sequence of still images(frames) to load on to my Camera in Houdini(3D animation application) -
It doesnt say it supports mov (and there are 100's of different kinds of mov)
Most vfx programs use tiff, dpx, or exr (and sometimes tga) -
1) add file to adobe media encoder queue
2) select format "tiff"
3) click on the hot text for the preset to adjust the settings - select "export as sequence" checkmark box, configure your file paths (directory to save it)
4) push start queue -
Thank you very much
I will try it now. and Can I get back to you if I still have problem?
Thank you very much again.
Steve
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 8Last Post: 10th Jan 2026, 14:42 -
xvid4psp settings to convert mp4 videos for SE w580i?
By secko in forum Video ConversionReplies: 2Last Post: 23rd Nov 2011, 10:27 -
Convert ISO MP4 Splited videos to Joining all
By fidogenial in forum EditingReplies: 0Last Post: 21st Nov 2011, 18:11 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 08:41 -
converting videos to MP4/PS3 with SUPER - gray flashing frames
By xycer in forum Video ConversionReplies: 1Last Post: 8th May 2007, 18:47
