I am using VirtualDub and wondering is it possible to split AVI to x parts in one operation.
Anyone know how to do it?
I have a movie where watermark (logo) appear only in some periods of movie.
So using DeLogo filter, I don't want do re-encode the whole movie.
I want to split AVI to parts and append DeLogo filter only to these parts with watermark.
Then I will join the movie.
So, how to define in VirtualDub custom splitting points allowing you to split AVI to desired number of parts?
I don't know about the splitting idea you have....but this cool option is also available in VDub:
http://www.youtube.com/watch?v=2MWoVY9mYbk -
hech54, yes but please notice that every subtitle line has a diffrent lenght on a screen.
I don't want to apply to DeLogo filter the longest possible matching clearing frame - as it lose quailty too much.
I want to append custom DeLogo clearing frames to every subtitle (to cover ONLY subtitle areas, not more!), no matter it will take A LOT of time. For me the final effect matters only.
Does anyone have a suggestion how to do it in a batch?Last edited by ralf07; 5th Apr 2012 at 18:00.
So just add several iterations of the delogo filter, each applied to a different range if frames.
If you still want to split the AVI into multiple parts use the File -> Save Segmented File AVI option. But you don't have control over where the segments start and end, just file size or number of frames.Last edited by jagabo; 5th Apr 2012 at 18:16.
No video in virtualdub after cut and split avi
By cooljoe666 in forum Video ConversionReplies: 10Last Post: 10th Jan 2011, 16:19 -
How can I split 10 GB divx movie into 4 parts?
By andy99 in forum EditingReplies: 3Last Post: 2nd Oct 2010, 17:05 -
How do I split .mkv file to two parts?
By dilanalex in forum EditingReplies: 1Last Post: 8th Apr 2009, 04:08 -
Cannot split H.264 720P AVI using virtualdub
By frankyloves2sing in forum EditingReplies: 7Last Post: 24th Jun 2008, 20:55 -
Program to manually split multiple parts of same avi?
By majax79 in forum EditingReplies: 5Last Post: 22nd Dec 2007, 11:49
