Dual layer DVR? Don't you mean "double-sided" ? ?. They will play dual-layer DVD's, which are common in retail DVD production..
Buy a blank dual-layer disc and try it out first.
Results 31 to 36 of 36
Some Panasonic DVD recorders will both play and record DVD+R DL media. I don't know enough about the Samsung models to say if any can record or play DVD+R DL media. Verbatim DVD+R DL is the only good choice for dual-layer recordable media.
Try the Roxio capture device and the DVD recorders on the same tapes and see which you like better. -
i just got roxio easy vhs to dvd package with upgrade easy vhs to dvd 3-- and i can not get it to work
it jam up each time i try to use it-- and ther support is in india-- not mush help tell me to try this and that-- think i just kiss away 50.00
i have to agree ther hardware look cheap-- look like the stuff that sell on e bay made in china
has any one had a problem with roxio easy vhr to dvd 3-- geting it to work i mean
and did you know corel bought out roxio--- support has to go through corel now--- and ther support worst then roxio wasLast edited by dirtfarmer; 30th Apr 2012 at 23:14. Reason: more info
I did the exact same thing, except with 8mm tapes only; but about the same age.
I bought a used Sony TRV480, popped the 8mm analog tapes in, and the camcorder simply played them back via FireWire. This method is the absolute best and is platform independent. Also, you can use the TRV480 as a converter from composite to FireWire - for your VHS tapes. on the TRV480 you can input a composite source, and output it to FireWire. The HandyCam has some internal processing that makes the resulting video better than absolutely anything any USB video capture device.
I switched to mac in 2007, so I think I can help you out on another level too.
If you decide to go this route - you will want to download and install Apple's Firewire SDK. I think the current version is 26. In that SDK there are a few small apps that will let you capture DV via any Firewire source.
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
Beginner's Approach to Digitizing VHS/Hi8 Tapes?
By Obtong in forum Newbie / General discussionsReplies: 8Last Post: 10th Jul 2011, 22:08 -
Cheapest way to xfer vhs tapes to pc or dvds
By majax79 in forum Capturing and VCRReplies: 4Last Post: 20th Jul 2010, 10:46 -
i need help to remaster my old vhs tapes to dvd quality(for mac or windows)
By ultimate15red in forum EditingReplies: 2Last Post: 12th Nov 2009, 06:13 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum Capturing and VCRReplies: 7Last Post: 4th Jan 2008, 22:19
