Results 1 to 14 of 14
    Jan 2012
    america
    Hey guys
    I have a question... Do you know of any good converter that can convert .avi to .mp4 ?
    I have tried SUPER but it converts an .avi file of 300 MB to an .mp4 file of 1 GB (or more i stopped the conversion halfway through)
    I also tried to convert to .wmv but the quality is tragically reduced ( the frame size too ), the video file I need to convert is in 480p which isn't that good and if I have more quality loss, it would simply suck.
    I need them to be converted in .mp4 because I want to edit them in Vegas Movie Studio HD Platinum 11.0.
    Thanks a bunch
    Oct 2005
    666th portal
    use mediainfo in text mode on the source avi and copy/paste the results here. you would be much better off using the original avi in vegas. i assume it won't import but there may be a way to fix it.
    Jan 2012
    america
    Ok, Thanks for your time!
    Here it is!
    General
    Complete name : C:\Users\Windows 7 Pro\Desktop\[K-F]_One_Piece_018_[2B3A4FC1].avi
    Format : AVI
    File size : 177 MiB
    Duration : 24mn 4s
    Overall bit rate : 1 030 Kbps
    Writing library : VirtualDub build 13870/release
    Video
    Format : MPEG-4 Visual
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 24mn 4s
    Bit rate : 892 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.121
    Stream size : 154 MiB (87%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 24mn 4s
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 22.0 MiB (12%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
    Jan 2012
    america
    Yeah, Vegas doesn't import it :/
    Jan 2012
    america
    Wow, it worked!
    Thank you so much guys!!!
    Jan 2012
    america
    is there a H264 codec ?
    Jan 2012
    america
    Hey guys
    so now i have another problem !
    first of all this xvid codec you gav me worked then i downloaded the avi and it was cool .. till i came up to some episodes where vegas didnt support the audio ! it accepts the file but it doesnt add the audio string!
    this is the info of the file !
    General
    Complete name : C:\Users\Windows 7 Pro\Desktop\One Piece episodes\One Piece episode 167.mp4
    Format : MPEG-4
    Format profile : JVT
    Codec ID : avc1
    File size : 231 MiB
    Duration : 23mn 5s
    Overall bit rate : 1 401 Kbps
    Encoded date : UTC 2005-12-11 03:34:10
    Tagged date : UTC 2005-12-11 03:34:10
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : No
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 23mn 5s
    Bit rate : 1 270 Kbps
    Maximum bit rate : 6 495 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate mode : Constant
    Original frame rate : 11.988 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.172
    Stream size : 210 MiB (91%)
    Writing library : x264 core 42 svn-384
    Encoding settings : cabac=0 / ref=1 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / pass=2 / bitrate=1270 / ratetol=0.7 / rceq='blurCplx^(1-qComp)' / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=16.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones
    Tagged date : UTC 2005-12-11 08:34:10
    Audio
    Format : MPEG Audio
    Mode : Joint stereo
    Codec ID : 6B
    Duration : 23mn 5s
    Bit rate : 128 Kbps
    Maximum bit rate : 132 Kbps
    Stream size : 21.1 MiB (9%)
    Writing library : LAME3.90.3
    Encoded date : UTC 2005-12-11 08:34:07
    Jan 2012
    america
    Anyone can help me please ?
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Please wait some DAYS before you bump the thread.
    No I have no idea why standard mp3 wont work.
    Jan 2012
    america
    Oh ok then I have another question ...
    I have other avi that dont get supported....
    but the codec isnt Xvid but H264 coz its HD
    is there some way to make it supported .. convert or codec?
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    You can try install ffdshow. And you must enable the vfw h264 decoder in it, from the start menu->ffdshow->vfw configuration and select decoder and under codecs select h264/avc libavcodec under decoder.
    Screenshot:
    Jan 2012
    america
    OMG IT WORKED!!!
    I LOVE THIS FORUM
    do i have to keep the program ffdshow for vegas to accept the files from ow onwards ?
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, it must be installed if you want to import h264 video.
