Results 1 to 14 of 14
    Feb 2005
    EARTH
    hello!
    how do I extract the audio of a video file?
    thanks!
  2. Member bat999's Avatar
    Feb 2008
    Originally Posted by ecos View Post
    a video file
    Which video file?
    Jan 2012
    Victoria, Australia
    Type your question in the search box and click on search
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    A bit more info would help - avi, mkv, mpg, flv, vob, etc etc different solutions.
    Best to post a mediainfo report (text mode) and then we will all know...
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Pazera Free Audio Extractor supports most formats.
    Feb 2012
    Lyon France
    If you are not an expert you may use Coyote free video converter (http://www.koyotesoft.com/).
    Be aware :this is not real free ware and you will get a lot of useless ware when you download it if you don't care.
    You will be able to easily convert from many video formats to mp3 (I suppose this is what you want to do).
    the free version has an output size limit of 1 GB ,but that doesn't matter for audio.
    If you are an expert it will be better to use some video demultiplexing tool an an audio reencoding tool if needed.
    VLC can do it but I do not like the converting tool of VLC.
    Feb 2012
    Lyon France
    the free version has an 1 GB output size limit, but that doesn't matter for audio.
    Feb 2005
    EARTH
    I didnt thought that there are so many ways to do one simple thing
    General
    Complete name :	\...\M2U645.MPG
    Format :	MPEG-PS
    File size :	649 MiB
    Duration :	24mn 54s
    Overall bit rate mode :	Variable
    Overall bit rate :	3 691 Kbps
    Video
    Format :	MPEG Video
    Format version :	Version 2
    Format profile :	Main@Main
    Format settings, BVOP :	Yes
    Format settings, Matrix :	Custom
    Format settings, GOP :	M=3, N=12
    Duration :	24mn 34s
    Bit rate mode :	Variable
    Bit rate :	3 170 Kbps
    Maximum bit rate :	9 100 Kbps
    Width :	720 pixels
    Height :	576 pixels
    Display aspect ratio :	16:9
    Frame rate :	25.000 fps
    Standard :	PAL
    Color space :	YUV
    Chroma subsampling :	4:2:0
    Bit depth :	8 bits
    Scan type :	Interlaced
    Scan order :	Top Field First
    Compression mode :	Lossy
    Bits/(Pixel*Frame) :	0.306
    Stream size :	557 MiB (86%)
    Audio
    ID :	189 (0xBD)-128 (0x80)
    Format :	AC-3
    Format/Info :	Audio Coding 3
    Mode extension :	CM (complete main)
    Muxing mode :	DVD-Video
    Duration :	24mn 33s
    Bit rate mode :	Constant
    Bit rate :	448 Kbps
    Channel(s) :	6 channels
    Channel positions :	Front: L C R, Side: L R, LFE
    Sampling rate :	48.0 KHz
    Bit depth :	16 bits
    Delay relative to video :	-112ms
    Stream size :	78.7 MiB (12%)
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Tsmuxer, add the mpg, select the ac3 audio track, demux. Or https://www.videohelp.com/tools/sections/video-de-multiplexers
    Feb 2005
    EARTH
    thanks!
    now i need to convert it to a more mainstream audio format, as lossless as possible :S
    any tool?
  11. Member olyteddy's Avatar
    Dec 2005
    AVI DeMux is a pretty versatile converter. Load your video, set the audio to what you want for output and click 'Save' in the audio drop down menu. Remember to add the extension to the filename as AVI DeMux doesn't automatically do that.
  12. FormatFactory will do most video to audio, audio to audio conversions.
  13. Member Cornucopia's Avatar
    thanks!
    any tool?
    Ac3 isn't common enough for you? Just get an Ac3 decoder for Acm/Dshow and you're done - ready to listen. Avoiding transcoding is as lossless as you can get.
    Feb 2012
    Lyon France
    To ecos : only demultiplexing is lossless .
    .MP3 is a most mainstream format , you may have good quality by choosing high bit-rate such as 256 kbits/second or higher . Quality will also depend on your re-encoding software with the same bit-rate ,but I can't tell you more about this.
    To olyteddy : Thanks ,I didn't know avi demux could output audio files,I will try next time.
