If you are running 64 Bit OS try the 32 bit dll seems that the 64 bit doesn't recognize in VLC on 64 bit OS but 32 bit dll will work, i have just successfully ran my first encrypted blu-ray in vlc.
Results 61 to 64 of 64
Well the 32 bit
goes toCode:libaacs.dll
whereCode:X:\portableapps\VLCPortable\App\vlc
is your portable drive andCode:X:\
is where vlc is installed and the keyfile goes toCode:X:\portableapps\VLCPortable\
where Users is the users directory and YourUserName... - well you know the rest.Code:C:\Users\YourUserName\AppData\Roaming\aacs\
Edit: As you can propably guess, this procedure won't be portable, since the users home directory is used, (must be repeated on every computer).Last edited by kw4nta; 5th Mar 2014 at 15:07.
Wow, almost a year later, didn't expect a response, but hey good to know someone figured it out. I'll give it a try when I have time
Problem with Blu-ray rip file playing in MPCHC and VLC
By brianp6621 in forum Software PlayingReplies: 1Last Post: 19th Oct 2009, 12:26 -
Can i use a blu-ray reader to Rip my Blu-rays ?
By fairwind in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2008, 12:04 -
can i use a blu-ray reader to rip my blu-rays?
By fairwind in forum DVD & Blu-ray WritersReplies: 2Last Post: 28th Nov 2008, 14:08 -
Is it possible to watch Blu Ray movies on your HD TV using your...
By pwangdel in forum Software PlayingReplies: 2Last Post: 2nd Nov 2008, 18:46 -
Nero Blu-Ray/HD plugin problems
By lostinlodos in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 20:01
