Finally finding a use for MKV (or in this case: MK3D), I have the one big question: How the heck do I make them?
Results 1 to 11 of 11
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
3DBDBuster (AIO package) or MKVToolnix, IIRC. Probably others...
Scott -
MKVToolnix does not have the option (unless it is hidden), and 3dbdbuster is -only- for 3D Blu-ray.
I figured making a 3D MKV meant just that. If I wanted to rip a 3D Blu-Ray, I'd say "rip 3D BlD"
I'm using two AVIs with the left and right channels. It's either that or I can rip them from a 3D "interlaced" DVD (the old format). I don't know of any that rip the old-style 3D.MKV: Merely Krappy Video.
Mkvmerge part of mkvtoolnix. Video property "--stereo-mode". It's just an argument in the CLI command. I don't know why you would call that hidden unless you're unfamiliar with CLI apps.
Scott -
Ok, I try the stereomode flag... and found it -only- works for the "squeezed in" video file. I have two video files separate, and need the "TrackOperation" field, and cannot locate it. Any help locating and how to program it is appreciated.
Well, that's one of the faulty or incomplete features of MKV: it doesn't describe all the known (or unknown) ways of containing 2 views.
Here's a short list of fairly common variations that aren't even accounted for:
1. Separate (but linked) files
2. Dual-muxed streams (I'm a big fan of this one
3. MVC (yes, it's within the video stream, but there should be a metadata flag to help the container parsers understand it)
4. 2D+Z format (like Phillips WowVX)
5. Side-by-side FULL or Top/Bottom FULL
6. A file of captured HDMI 1.4 "FramePacking" stream
7. Anaglyph (Blue/Yellow)
8. SIS format
There are others.
So your choice is whether to use another format (maybe not even MKV) that will work with your system, that you can fully describe to the system, or to re-encode (to something like regular SbS (Anamorphically squeezed in 1/2).
AFA "TrackOperation" (which may or may not work the way you want it to), you are supposed to be able to use MKVToolnix's mkvpropedit (it's a CLI app) to apply this, but when I look at its CLI switches, I don't see it. Plus, I see on a few MKV dev forums that the TrackOperation hasn't fully been implemented in ANY MKV muxer yet (at least as of 1 yr ago).
Scott -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
how to make mkv to dvd
By ashe09 in forum Authoring (DVD)Replies: 3Last Post: 15th Oct 2011, 21:55 -
Make MKV Like Programs
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 3rd Dec 2010, 17:23 -
Need some help make an MKV video
By kenryuakuma in forum Video ConversionReplies: 1Last Post: 4th May 2009, 04:43 -
Any tools that can make a .mkv from VC-1 input?
By mkvbob in forum Video ConversionReplies: 22Last Post: 12th Nov 2008, 09:26
