Hello. I've been using XMedia Recode for ~month now, and everything worked fine up until yesterday. Now, whenever I go to the Filter/Preview tab I get this: https://forum.videohelp.com/images/imgfiles/28I5x.png , and the program locks up until I close it. As far as I can tell, all filetypes are affected (although I only have .mp4s and .mkvs to test it).
So far I've tried uninstalling/reinstalling, installing an older version of the program, and using the portable Xmedia; and nothing's work.
Any suggestions?
Hi BoxesofBags,
You must have done something ... btw, what is your OS?
1) Uninstall completely and Restart PC.
2) Then install version 3.0.5.6 or 3.0.7.6? If the .exe did not work ... then use their Portable version!
Post back your result for the next person!
Thanks!
G!
Hi BoxesOfBags,
I am no expert in this field ... but somehow ... someone always comes to my aid at VH ... so, I am going to try to help you with my limited knowledge ...
I just visited the XMedia Recode download page and I see multiple people are having luck with version 3.0.8.0 ... and their OS is same as your Win 7, x64.
FYI, my OS is Vista Home Prem., x64.
Trying installing version 3.0.8.0 .exe ... if that doesn't work ... the other thing I would try is Right-Click the XMedia-Recode shortcut and go to Properties > under Compatibilty choose Run in XP Mode ... see if that helps ... but you shouldn't have to do that ...
Q: Have you Added or Deleted any other Programs ... when this happened?
Thanks!
G!
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 23:29 -
No video preview with Xmedia Recode?
By smackyourfupa in forum Video ConversionReplies: 10Last Post: 2nd Jul 2011, 19:44 -
Xmedia Recode preview/save error
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2011, 07:25 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 16:40 -
I downloaded dvdflick and it missed the "audio" tab in the projec
By chriskimber in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2007, 17:53
