Results 1 to 12 of 12
  1. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hey, does anybody out there know if these are real? I cut into the small one and it was silver.
    Apr 2002
    The State of Frustration
    Hard to really say. They say a good rule thumb is that potential meteorites are unusually heavy to be just an ordinary rock. But since your signature say you may be in Los Angeles, I would go over to their science department and ask them. They would be more than happy to look into it for you.
    Hello.
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Yeah, they're heavy for their size.
  4. And where did you find those Bud?
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I found them pressed into the ground, and visible, near an abandoned RR track.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Neat find. Keep us updated please
    Oct 2010
    England
    Sure it's not just a hunk of rusty metal?
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I'm starting to think it's "slag".
    It meets ALL the criteria for a meteorite, except I sanded off a small flat part and tried to etch it and it doesn't react to the acid.
  9. Yes, it could be slag. The railroad may have used crushed slag for their roadbed instead of gravel. Or maybe they used a portion of slag mixed with gravel. Remember, there was once a big steel mill not too far from you located in Fontana, CA. They produced tons of slag.
  10. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Yep, BUT!
    My rocks are extremely hard to cut. Wears out the metal sawzall blade. Very dense. Hang on, let me show you the latest picture.....
    I didn't set the WB. There's no green on the rocks at all. Only black and brown(rusty).
    Is This black stuff "Fusion Crust"? This WILL flake off if I use a knife. It actually is a crust, not a coloration.
    Apr 2002
    I still think it just may be a meteorite. If I were you, I would take that puppy down to the UCLA Science Department and ask them to run some tests and THEN get back to TreeTops and the rest of us.
    Hello.
  12. Member olyteddy's Avatar
    Dec 2005
    I grew up in an industrial kind of town (Electro-Chemical mostly) and the railroad tracks near my house used all kinds of weird looking rock for ballast. I recall a lot of what they used was slag and clinkers from that chemical industry and finding rocks like that wasn't uncommon. Those are good looking rocks though, and if there's a museum or college nearby you might have someone take a look.
