I am having big problems with both Replay and WM Recorder this year with streaming games. Games which used to be streamed at 460x380 resolution have recently started streaming in HD requiring the Microsoft octoshape plugin.
Normally with both Replay and WM Recorder, if you try to cap a game real time you get hundreds of small half meg files, like this:
1214_XXX_HFD.wmv
1214_XXX_HFD(2).wmv
1214_XXX_HFD(3).wmv
1214_XXX_HFD(4).wmv
1214_XXX_HFD(5).wmv
1214_XXX_HFD(6).wmv
1214_XXX_HFD(7).wmv
1214_XXX_HFD(8).wmv
1214_XXX_HFD(9).wmv
1214_XXX_HFD(10).wmv
etc......
Now the HD archives which are no longer being played real time the same day are all being captured the same way! Both stream catcher software's seem to think they're live games. I have both up to date programs Replay Media Catcher 4 and WM Recorder 14.
I'm ready to try just about anything to get this to work.
Thank you.
You aren't gonna give us a link to that webpage.
Hi Bahman, I try your method. All I got was "File not found" for each chunk. I even tried batch with authentication. After I close batch and try with single URL, I get a message "invalid URL".
Did it work for you? -
wildcard must be "4"!! Did you change it?
and of course file with these names are invalid:
0001,0003,0005,0007,0009
and there are only:
0000,0002,0004,0006,0008, and so on!! -
Ok, I did not add 0001, 0002 etc at the end of the url string. I just added the first URL into the batch recorder, and I did change the batch settings per your instruction.
capture and playback of udp streams
By tuxeric in forum Video Streaming DownloadingReplies: 3Last Post: 29th Mar 2012, 07:38 -
Download Octoshape video
By ashuras in forum Video Streaming DownloadingReplies: 1Last Post: 17th Sep 2011, 04:18 -
How can I capture silverlight streams
By RMWolfe in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2011, 00:00 -
Anyone know how to capture NBCOlympics.com video streams
By peggypwr1 in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2008, 02:01 -
Capture Multiple streams to Mac
By joust888 in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2008, 12:03
