1.(Most Important) Im looking to do some light video editing (Maybe 5-6 instances of 1080 30fps ontop each other on the timeline and a few effects)
2.Some DAW work in Ableton
3.(Least Important) Maybe some gaming if possible. Doesnt have to be on Ultra
I need some help to know if my unit is up to spec and are my componant matched up correctly.
I have a budget of $700 and already have 26" 720p LCD, Wireless Mouse and Keyboard, DVD Drive and 1TB Ext HD. Im planning to buy this next Thu. from Micro Center and this is what i have so far. I think this is a link into my checkout list on Micro Center.com
http://cart.microcenter.com/cart.aspx?RedirectUrl=http%3a%2f%2fwww.microcenter.com
If that link doesnt work:
Intel Core i7 2600K LGA 1155 Boxed Processor 279.99
SKU: 200154
ASUS P8Z68-V LX LGA 1155 Z68 ATX Intel Motherboard $119.99/$69.99 w MB
SKU: 812289
Corsair
Vengeance Series 8GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 4GB Memory Modules) $59.99
SKU 403980
Cooler Master Hyper 212 EVO Universal CPU Cooler $36.99
SKU 888438
Cooler Master TC102 Mid Tower ATX Computer Case with 500W Power Supply$36.99
SKU 417642
Manhattan 60-in-1 Internal 3.5" Bay USB 2.0 Multi-Card Reader/Writer $14.99
SKU 661504
Enermax LEPA Series 120mm Sleeve Bearing Case Fan $3.99 (4 quantity)$15.96
SKU: 179838
Cooler Master Silent 140mm Case Fan Cooler Master Silent 140mm Case Fan $12.99
SKU: 594820
XFX HD677XZNLC AMD Radeon HD 6770 1024MB GDDR5 PCIe 2.1 x16 Video Card $129.99
Results 1 to 24 of 24
That setup will do you fine but get a better psu,i got a antec 4 rail 750w for $50 with free shipping so there are better psu you can find.
can save $15 on the RAM if u go to newegg
RAM
save another $15 on the CPU Cooler...read around online and see that the Hyper 212 Plus and the Evo have virtually 0 differences...your talkin maybe .5 degree C in temp difference...save the money and get a 212 Plus
CPU Heatsink
you can save $35 if you get the video card at newegg
Video Card
I agree with johns0...get another power supply...one thats at least bronze certified -
Ram and Video Card: OK i will check that out, maybe i can get em to price match.
CPU Heatsink: I cant find that EVO one you suggested, and is it quite? I need quite for audio recrding purposes.
And do i really even need this CPU Heatsink? Will the one that come with the i7 suffice?
The motherboard says it need atleas 430W. Should i be lookin for 430W or above? -
If you are not against using a different brand of RAM, and if it's compatible with the MB you are going to use, Micro Center carries this:
http://www.microcenter.com/single_product_results.phtml?product_id=0360527
I have it on a couple of my PC's, and it works very well. -
no im not against any of it..My original budget is 700 and i still dont have a Hard Drive. Thanks for the savings.
As far as that Heat sink goes..i dont plan on over clocking(never even tried it and most likely wont) do i really need it with all the 4x 120mm and 140mm fans that will be in the case? -
you can use the retail hsf with the i7. no one claims it's quiet. for near noiseless fans and a hsf look into noctua. they are what i use, but they are not cheap.
I think ill see how it goes without the heat sink and upgrade that if needed.
Now it seems that i need to scrap the case and get a seperate power supply
Well im back down to $538.93 without the Case, PSU and Hard Drive.
You guys suggestion have been A1..thank you..Im not so much con cerned about the Drive, they seen to be non-negotiable right now.
But some help on the Case and PSU would be helpful. -
Buy the hsf you listed,the stock hsf is crap and will get very hot while encoding and don't bother overclocking with the stock hsf if you ever do.
what size case? micro, mid, full tower?
I think the motherboard is an ATX. At most ill have two hard drives in there. I dont think ill need a big one. I dont care for flashing lights either. Considering one of these $19-25 cases. But im sure you guys would know better than me.
your choice of video card is a fairly short one so it should fit in just about any case.
this thermaltake is pretty cheap for a well known brand mid-tower after $10 rebate with free shipping. today only.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133094--
the component i wouldn't go cheap on is the power supply. get a decent ocz, seasonic, corsair or equivalent. something like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017--
Anything in the $50-55 range for PSU that will work? By the way im going with that case you recommended
the one i linked to above is 50 after rebate. + 6 shipping.
Thanks everybody for your patience.
If i can get this PSU selected ill be done.
Can yall take a look at these two. I selected them from the name brands yall mentioned.
http://www.microcenter.com/search/compare_products.phtml?search_id=f4037a94bf9dc1722aa1bef5df89ce03
Are they suitable? I think the more expensive one even has a rebate. -
The link you provided is out of date,no products to compare.
Sorry. The two in question were:
http://www.microcenter.com/single_product_results.phtml?product_id=0348766
http://www.microcenter.com/single_product_results.phtml?product_id=0303417
Both the Brand names were mentioned in this thread, though im not sure if these supply enough power.
If not i will purchase the one aedipuss chose.
I was trying to keep this build inexpensive and it has proven to be tougher than id imagined. -
in today's email from newegg they are having a special on a 600watt ocz. if you use this promo code EMCNHJC23 for $10 off and send in the rebate the final cost is $39.99 with free shipping.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017&nm_mc=EMC-IGNEFL021712..._-17341017-L0A--
Thank you fellas for helping me wit this build. I decided to go with the i5 2500K because the extra hundred woulda pushed me to the $800 dollar range. It took me damn near 12hours to install. (Trouble Shooting) The computer wouldnt boot and kept saying CPU Fan Error! After doing some looking. Ifound the everybody have a different solution to the problem, which point to the motherboard. My solution: Take the Cooler Master Hyper 212 off and put the stock heatsink cpu fan on. I'll be returning the Hyper 212.
Intel Core i5 2500K
ASUS P8Z68-V LX
Kingston HyperX blu 8GB DDR3-1600
WD Caviar Blue Sata 6.0 500GB
OCZ Modxstream pro 600
Thermaltake V4Black case
and Five 120mm fans
Total: $699.95 at Micro center and about $80 worth of rebates not yet recieved.
One last question. In Device Manager under "Other Devices" there are exclamation mark next to Ethernet controller, PCI Simple Communications Controller, SM Bus Controller and Universal Serial Bus (USB) Controller.
Do these have to do with the motherboard and how can i correct this? -
Sounds like you plugged the hsf into the wrong header and plugged the stock hsf in the right header,i did that once thinking the Cooler Master Hyper 212 was faulty until i double checked the connections.
most of those exclamation points in hardware should go away if you install the chipset inf driver from intel.
Computer build questions on motherboard brands and cpu specs- vid encoding
By yoda313 in forum ComputerReplies: 68Last Post: 31st May 2011, 08:55 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 16:54 -
Capture to MPG on timer
By bolintx in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2008, 18:20 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 20:33 -
Help with Timer in Sony Vegas 6.0
By petersju in forum EditingReplies: 1Last Post: 11th Jun 2007, 20:54
