Hi,
Why i am unable to play 3D movies directly from my PC.. TV doesn't show 3d SBS converting 3D option but only 2D to 3D.
TV MODEL : LG 32LW4500 3D LED LCD TV
PC: CORE 2 DUO 3 GHz WIN 7 4 GB RAM ATI RADEON 5550 HD Graphic Card
PC connected with TV via HDMI
Pleaseeeeeeeeeeeee help !!!!!!!!!!!
Results 1 to 9 of 9
[QUOTE=Baldrick;2141721]rollcage7: Please stop cross post everywhere.
apologize for this inconvenience but desperate to get feedback ASAP -
Much more info needed to even begin to help: playing app - you list 4, which os (32 v 64bit), file rez &framerate, displaycard output rez settings when in fullscreen mode (you are in fs mode right?)...
Scott -
rollcage7: I have now moved your post to a separate thread. PLEASE DO NOT POST ANYWHERE ELSE.
Shall the same job will do by blue ray player LG BD660.. Connected with Portable hard drive ?
Actually my 3DTV doesn't support DTS audio and limited frame rate 8 to 30 fps
I want to play 3d movies bypassing PC or any external media...
Please suggest best for me -
Where did you get that idea? Your TV will not do passthrough of DTS from the optical toslink out from your TV, that's all. It will output PCM stereo to your receiver, if your setup is like that. As to limited framerate, huh?
Anyway, I have the LG 65LW6500 and can confirm it will play h.264 mkvs and transport streams from NTFS formatted thumb drive or external hard drive. (Haven't hooked up my HTPC yet, been busy remodeling a room for my new toy.)
I suggest you put a 3D video on thumb drive or external hard drive and connect to one of the USB ports. Simply to test whether your TV is working properly. BTW, are these legit files, meaning they're encoded correctly? You can download sample 3D files to be certain the problem isn't there.
Also, my TV didn't offer me all options in settings right away. It took a few times turning off, unplugging for awhile, then restarting to get everything up and running correctly. I thought it might need a firmware update, but no, I have the latest. Although you might check to see if there's a newer firmware update available for your TV.
Here's a dedicated thread on your model TV, maybe you'll find something useful there:
http://www.avforums.com/forums/lg-forum/1393486-official-lg-lw450u-3d-led-thread.html
Good luck.Pull! Bang! Darn!
Player that can play files burned directly from HD camcorder?
By mccake in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Dec 2011, 21:59 -
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 23rd Nov 2011, 00:04 -
Can I export edited Movies back to DV tape directly?
By Yim in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Aug 2010, 17:03 -
Netflex streaming movies directly to your TV
By rcguy1 in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2008, 14:46 -
WMP doesn't play hyperlinks directly
By jemoto in forum Software PlayingReplies: 4Last Post: 16th Mar 2008, 00:37
