Hello, is there any program which i can easy to use to remove audio from VOB Files and insert another Audio. Btw what program i must use to extract all files within VOB and mixed them again ?? Also which program to convert MP3 to AC3 or format that VOB compatible. Im using Windows ...
Thx for reading
You can use tmpgenc authoring works and mpeg video wizard dvd and load your dvds and replace the audio directly. You will lose original menus, chapters, etc.
If you are looking for free tools must you use more tools.
Convert your mp3 to ac3 with old ffmpeggui or EncWAVtoAC3 or audacity.
Extract the video and audio from your dvd with pgcdemux.
Reauthor the old video and the new ac3 audio to a new dvd with muxman.
You can then add back the original menus with vobblanker.
Click on the tools for some guides, like https://forum.videohelp.com/topic338721.html (Method 2 and skip the subtitle part.)
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2013, 07:50 -
vob 2 video + audio then increase audio volume then recombine to vob or mpe
By indyram in forum Authoring (DVD)Replies: 6Last Post: 14th Dec 2011, 02:55 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 02:17 -
Remove person from one video; insert into another
By liquidz76 in forum EditingReplies: 3Last Post: 26th Dec 2009, 21:52 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03
