Results 1 to 9 of 9
  1. Hey i keep getting the following error when trying to import a video into Adobe Encore.
    "The software that's used to decode the media is not available on this system. Installing the correct decoders for the files you are working with may help to correct the problem."
    I've checked which codec was used for the file and its VC-1 WMV3 i think?
    Any idea where i can get hold of this?! ASAP please! I dont mind having to convert it otherwise as long as i can try and retain the quality as best as possible,
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    If it's wmv, try installing windows media player.
    Or Freemake to a codec your system already has
  3. Thanks!
    I already have WMP, i guess ill have to try convert it
  4. Member leghorn's Avatar
    Apr 2007
    Germany
    There's a Windows Media Redistributable Package by MS (wmf11redist). AFAIK, you should install this first. Or maybe you could use Windows Movie Maker to convert the file to some lossless format which is supported by AE.
    If your video is some Blu-Ray stream you might use Handbrake to open and convert it.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
  5. Hey,
    Below is my MediaInfo export, any idea what i can convert it to for the least amount of quality loss?
    General
    Complete name : D:\NAMEREMOVED.wmv
    Format : Windows Media
    File size : 5.57 GiB
    Duration : 1h 37mn
    Overall bit rate mode : Constant
    Overall bit rate : 8 203 Kbps
    Maximum Overall bit rate : 8 385 Kbps
    Encoded date : UTC 2012-02-15 20:14:08.615
    Video
    Format : VC-1
    Format profile : MP@HL
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9 - Professional
    Duration : 1h 37mn
    Bit rate mode : Constant
    Bit rate : 8 000 Kbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.206
    Stream size : 5.43 GiB (98%)
    Language : English
    NumberOfFrames : 0
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 9.2 - 320 kbps, 44 kHz, stereo (A/V) 1-pass CBR
    Duration : 1h 37mn
    Bit rate : 320 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 222 MiB (4%)
    Language : English
  6. WMV3 comes with windows install. But other WMV codecs like WVC1 come with WMP11 or 12
    Just convert it to whatever format is going to be used for authoring, that way you only incur quality once instead of twice (this way Encore doesn't have to re-encode it)
    => if you are using Encore for DVD, then convert it to DVD compliant MPEG2
    => if you are using Encore for BD, then convert it to BD format (e.g. AVC, or MPEG2)
  7. BTW, that is a very weird error that encore is giving you...
    WMV3 should be accepted without installing external codecs
    Where is this from? is it possibly DRM protected ? Can you play it in VLC ? or only WMP ?
    (If it only plays in WMP, but not other players like VLC, MPlayer, then it's probably DRM protected)
  8. Its my own personal video. Its weird as it does play in VLC etc.
    Ill try convert it to MPEG2 and see what happens =[
  9. For anyone else who stumbles upon this thread.
    I managed to fix it, i had to convert it to .mpg using freemake video converter
