okay well im having some choppy playing from vlc, mpc, wmp, and even bino. wpm seems to work the best for 3d and bino seems to be the worst
i have all new codecs, software, everything. im running a athlon x2 dual core, 4gb ddr2, nvidia gtx 560ti, toshiba 47'' 240hz 3d smart tv, all on win 7 ultimate 64
what is the best way to get flawless 3d playback? i have nvidis 3d vision, and i have a 14 trial of nvidia 3dtv play
avatar seems to struggle the most, but harry potter seems to run pretty smoothly
u only need a min of athlon 64x2 2.60 to run 3D, now most 3d video is running great, but some stuff is lagging
no. tv's only playback 1920x1080 3d video as you have found out.
The way to play videos that wide is to use AVISynth (etc) to convert to Sbs anamorphically squeezed to 1920x1080 (which will need to be reencoded if you're wanting to save the file rather that play straight out).
Or,
You can play it in Stereoscopic Player, outputting with a method that IS compatible with your TV (Sbs squeezed should work here also). Just know that you need to have a PC that is capable of sustained output for a file of that resolution (not sure if yours really is - remember this file isn't your standard sbs 1920x1080 3D...).
MP4 file out of sync in VLC, not in MPC-HC
By M3mbr4n3 in forum Software PlayingReplies: 17Last Post: 9th Feb 2013, 16:07 -
MPEG2 playback via VLC or WMP darker than when viewed on NLE timeline
By sdsumike619 in forum Video ConversionReplies: 4Last Post: 15th Jan 2012, 18:24 -
major difference in playback quality between vlc and wmp
By octeuron in forum Newbie / General discussionsReplies: 6Last Post: 26th Feb 2010, 18:05 -
Weird Problem with MPC and WMP
By set69 in forum Software PlayingReplies: 4Last Post: 11th Feb 2009, 23:47 -
MPC v. VLC
By Ogilvy in forum Software PlayingReplies: 5Last Post: 7th May 2007, 10:05
