  1. Hi Baldrick,
    I like to share 2 things ...
    1) I am not sure it is my problem or there is an issue with the "Quick Reply" box ... when I want to use it ... I have to hover my mouse over it several times ... and tap my pad like crazy till I get the darn Blinking Cursor ... so I can start inputing my comment or Q.
    2) I wonder if you can add "Number of Posts" under people's Name/Handle!?!? I am not sure if this has come up ... or if there is any value to it! Just an idea!
    Thanks!
    G!
    1: Try change the message editor interface to standard, under https://forum.videohelp.com/profile.php?do=editoptions and at the bottom.
    2: Hover your mouse over the and you will see the total posts.
    edit: Changing message editor should solve it.
  3. Hi Bladrick,
    Thanks A Bunch! Your solution to change the Editor to "Standard" did the Trick! Matter of fact I am using the Quick Reply now!
    Also thanks for pointing me to the Post Count tool!
    As usual Appreciate the Help!
    G!
