I am a newbie and not sure if this is the right forum. I Decrpt DVD with DVDDecrypter and then burn using DVDShrink/Nero.
Some times, I cannot rip the few VOB files due to media errors or scratches. In this case I have all VOB but the last VOB is incomplete. It has end of the movie but not last 10 seconds. I am fine with that. I can play the VOB using media player and watch. Offcourse I can not watch last 10 seconds which are nothing but texts at the end.
When I try to encode using DVDshrink it gives me error. Is there any way to reduce (reencode) and burn the movie with incomplete VOB? Please let me know. The entire Video_TS folder is more than 5 GB it must be reduced by encoding.
Thanks,
	Be sure to try rip with dvdfab decrypter first. DVDDecrypter and dvdshrink hasn't been updated in years.
	If you have a 64 bit operating system and an NTFS HDD you can join all the VOBs together using something like VOBMerge and use DVD Flick to convert it to a DVD. If your system can't handle single files larger than 4 gb, however, then you can try converting each VOB to something smaller, say an AVI file, and join them together later. Once it's joined you can burn the AVI file back to disc using just the one file. See the Freemake Video Converter in the Tools section.
	For the VOB's you already have, try IFOedit to generate IFO's from the VOB's. You should probably use FixVTS on the results. In the future, use DVDFabDecrypter to rip, like Baldrick said.
  How to author & burn a DVD from VOB trailers/filesBy Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39
  SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHORBy jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 10:37
  how do I fix an incomplete vob download?By NotHarry in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2008, 12:43
  re-author a .vobBy forare in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2008, 02:20
  re-author minidvd withe one missing .vobBy Gondor in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 04:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
