    Feb 2006
    England
    I live in England but everytime I encode a mp4 with TVM5, it is encoding them as NTSC. I am encoding 720x576 and 25fps. Yet when I check in MediaInfo, it says the Standard is NTSC. Cant find any option to change it. Any ideas?
    Can you post the full mediainfo details? In mediainfo change to view->text to copy it.
    Feb 2006
    England
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.62 GiB
    Duration : 2h 14mn
    Overall bit rate : 1 725 Kbps
    Writing application : TMPGEnc Video Mastering Works 5 Version. 5.1.1.52
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 2h 14mn
    Bit rate mode : Variable
    Bit rate : 1 529 Kbps
    Maximum bit rate : 14.0 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.151
    Stream size : 1.44 GiB (89%)
    Writing library : x264 core 115
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=13991 / crf_max=51.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
    Material_Duration : 8062240
    Material_StreamSize : 1541309885
    Material_FrameCount : 201556
    Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
    Transfer characteristics : BT.470-6 System B, BT.470-6 System G
    Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 2h 14mn
    Bit rate : 192 Kbps
    Maximum bit rate : 576 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 185 MiB (11%)
    Material_Duration : 8062230
    Material_StreamSize : 193586169
    I guess mediainfo just shows correct standard(PAL, NTSC) for mpeg2/DVD and dv-avi. Other formats doesn't really need to use any pal/ntsc info.
    Feb 2006
    England
    So should I just ignore it?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes.
  7. Member Chef Goldblum's Avatar
    Feb 2012
    Planet Earth
    Yeah as Baldrick said, ignore it. Just forget PAL at all for HD video. And NTSC too for that matter. The only thing that makes HD either "PAL" or "NTSC" is the frame rate settings because the size of the actual frame on HD is the same now - unlike the analog days. 25fps is the correct option for "PAL" HD, so looking at your details here you're all set.
