Hello, is it possible to connect a Logitech x-530 5.1 to my TV and play 6 channel files with a WD TV, and how would you do it?
Nope,better option is to get a sound bar for your tv.
So is there no way to connect a 5.1 system thought the WDTV, or just not this one in particular? And would a sound bar be able to play 6 channel files?
You can connect a 5.1 system but it has to have an optical or co-axial or hdmi output,a good sound bar will have 5.1,depends on the cost.
Logitech Z5500 > Logitech Z906?
By Stealth3si in forum ComputerReplies: 2Last Post: 9th Nov 2011, 22:10 -
Logitech Revue $99
By MJA in forum Off topicReplies: 0Last Post: 31st Jul 2011, 13:52 -
attaching logitech sub to m-audio monitors
By gooberguy in forum AudioReplies: 0Last Post: 4th Sep 2010, 15:53 -
Logitech Harmony remote
By hummer in forum Off topicReplies: 2Last Post: 25th Jun 2007, 11:40 -
Logitech MX1000
By mccoady in forum ComputerReplies: 1Last Post: 23rd May 2007, 13:34
