  1. Member mew1033's Avatar
    Jul 2007
    I'm not sure exactly where I'm going wrong, but for some reason I just can't get MaestroSBT to recognize the Korean characters in my subtitle file. I've made some changes in Aegisub and saved it as an .ass (or .ssa) file. Then I try to open it in MaestroSBT. I change all the options I need to, but when I hit Edit & Preview, none of the Characters show up. There are a few English words, and they show just fine. Also, all the periods, commas, semi-colons, etc show up correctly, in the correct spot, on the Korean lines. But the Characters themselves just won't show.
    What have I missed?
    Thanks!
    A little nonsense now and then is relished by the wisest men.
    -Willy Wonka-
  2. DECEASED
    Jun 2009
    Heaven
    Make sure you save your SSA or ASS files in UTF-16.
    Also, set MaestroSBT to use the "codepage" 65001.
  3. Member mew1033's Avatar
    Jul 2007
    Got it!
    Thanks!
    I ended up having to select "Script font code page:" as "force Korean (Hangul)" That seems to have worked.
    Funny thing is, when I try to "Open UTF-8 file" It still fails. I have to just open it as a regular file.
    Thanks!
    -Willy Wonka-
  4. DECEASED
    Jun 2009
    Heaven
    You're welcome.
