Hi I need help please!
I have a NTSC tape and in a NTSC vcr and I'm in portugal which is a PAL country so NTSC is a bit hard to find so I don't have access to another NTSC vcr. The tape is old and it is getting worn out so I'm planning to do a VCD. When I try to capture it looses frames therefore loosing sync with audio in the resulting capture. These dropped frames are because there is vertical jitter on the tape keeping the image out of sync with the screen which sometime rolls. What I'm asking for is if someone can tell me a way to solve this problem like if there's a filter for vdub or any other kind of software that can correct sync. If I use the tracking function in the vcr It will stop rolling and there's no frames skiped but the screen gets full of those typical lines of a bad tracked tape. Will passing the signal through another vcr solve the problem? Will I be forced to buy a video stabalizer like those that defeat macrovision? I'm sure it's a sync problem just don't know how to fix it.
Results 1 to 1 of 1
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 18:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 17:56 -
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 19:26 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 21:26 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 02:41
