hi there
i've been given a hd camcorder (SONY HDR-hc3) it records to mini dv.
I would like to capture my tapes to best quality hd format. Could anyone give me advice about how to go about this?
i'm used to capturing avi files via firewire using premiere and then using tmpg but im not sure about:
best file format to capture in
processing power needed (im assuming that since they would be bigger files - this would be a factor
best software to capture with
cheers
The SONY HDR-hc3 records to HDV or DV format. If you record HDV, you can transfer either HDV or DV over Firewire.
For HDV capture use HDVsplit.
For DV capture use WinDV.
HDV playback requires adequate CPU and/or HD display card decode assist. What are your computer specs (CPU, display card/chipset)?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
hi there and many thanks for assisting
i should like to capture hdv with a view to editing content and producing a blu ray disc
my pc I7-2600 CPU 3.40GHZ
my display card is a Nvidia Ge Force GTX 560 Ti -
You are GO on computer hardware. A basic package for Blu-Ray editing/authoring is Sony Vegas Movie Studio Platinum. Free alternatives exist but are much more difficult to master. HDV is Blu-Ray ready for codec but the container must be changed from MTS to M2TS.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
