hi
i use Avidemux with x264 encoder to convert satellite streams (TS) into MKV.
everything was going on properly until i installed a bunch of Windows Updates. i don't know whether they caused it and if so which one of them to blame. but i get this symptom:
after i OK the dialog for the job to be added into the list of jobs Avidemux gets closed unexpectedly (exception). it occurs just after the .js file creates. because when i re-run Avidemux i see the job. this time when i go to run the job it Fails.
how can i realize what causes it to get closed and how can i resolve it?
thx
version of Avidemux: 2.5.6
Windows 7 Ultimate
Really ?!?!?!
A member for almost 4 years and you still don't know enough not to post the same thing twice ?!?!?!
And just as bad if not worse, you don't know what that big "EDIT" button is for ?!?!?! -
hamidi2, Do not post the same topic on several forums.
Please do not cross post, once is enough.
Continue in: https://forum.videohelp.com/threads/343560-901123-x264-to-mpg-converter?p=2141202#post2141202
Moderator redwudz
901123 - x264 to mpg converter
By hamidi2 in forum Video ConversionReplies: 4Last Post: 3rd Mar 2013, 03:58 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Need to know of program to close session and dvd disk
By pedote in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2011, 19:31 -
How to add video filters effect without encoding with avidemux?
By tendra in forum EditingReplies: 2Last Post: 1st Nov 2009, 02:44 -
Best program to add clips together?
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 02:47
